Trans Am engine swap
Old Jan 13, 2010 | 05:39 PM
JErgle42's Avatar
My dad is thinking about making an engine swap from a stock motor of an 85 Pontiac Trans Am to a 65 lt1. Now the problem is that he don't know how to wire it. If anyone could direct him through this process, i would appreciate it. You can e-mail me at JErgle42@gmail.com if needed.
EDIT:
Okay, I made a mistake above and the motor is a 96 from a 96 Roadmaster Buick.
Old Jan 13, 2010 | 06:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
"65 LT1"? Not sure what that would be. The "original" LT-1 came out in '70, was downgraded for '71-'72, but to the best of my knowledge, there was no LT-1 in the 60's.
Per chance did you mean '95 LT1? In that case, check out the LT1 swap sticky in the top section of this forum.
Old Jan 13, 2010 | 09:24 PM
JErgle42's Avatar
Re: Trans Am engine swap
Okay it came out of a 96 Roadmaster Buick and it is a 96. That was my mistake.
Last edited by JErgle42; Jan 13, 2010 at 09:26 PM. Reason: Incorrect information was posted
Old Jan 15, 2010 | 10:19 AM
JErgle42's Avatar
bump......
Old Jan 15, 2010 | 10:43 AM
five7kid's Avatar
Did you read the sticky?
It contains this link: https://www.thirdgen.org/forums/ltx-...g-dummies.html
Old Jan 16, 2010 | 04:22 AM
JErgle42's Avatar
Would that work; seeing as how it's a 96 and all? Or is there even a difference?
Old Jan 16, 2010 | 09:08 AM
Pocket's Avatar
Car: 91 Trans Am
Yes, Fbody and B-body LTx swaps are the most common and easiest
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
