throttle cable?
Old Jan 15, 2010 | 12:48 AM
rock861261's Avatar
throttle cable?
have a 91 camaro and am putting in a ls1 and wondering what throttle cable to use i read a 99 non traction controlled but i have to bend my gas petal anybody make this work with out bending the petal or use a different cable?
im also looking at the bm shifter that fits in the stock thirdgen console will this work with the 4l60e?
Old Jan 15, 2010 | 06:28 AM
Pocket's Avatar
Car: 91 Trans Am
Re: throttle cable?
LS1s used two different size TB cams. You must match the throttle cable to the TB cam
I think the years are 98-99 small cam, and 00-02 large cam. Google it and confirm
You must get a non traction cable. Normal cables go from the throttle pedal arm to the throttle body. Traction cables go from the throttle arm to the traction motor. Both the length and ends are different
Remember to put a large washer on the new cable so it can mount to the firewall
Dont worry about bending the pedal arm. It it just so you take advantage of the full throttle body range to WOT. Most people bend it a max of 1/2" but some are just fine leaving it alone
Old Jan 15, 2010 | 10:01 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Get a Lokar cable and you won't have to worry about bending the pedal.
The B&M console Megashifter will work with a 4L60E. Of course, you can program the PCM to shift where you want it, so the Megashifter probably won't be of much advantage. I'm seriously considering going back to the stock shifter from the Megashifter when I do the LS1/4L60E swap.
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
