LSX Swap strut tower brace
Old Jan 23, 2010 | 03:39 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Upon completing my LSX swap I plan on buying a strut tower brace. Will the one for the TPI cars fit? or do i get one for a TBI?
Here's what i'm looking at:
http://www.hawksthirdgenparts.com/ca...ctpricing.aspx
Thanks, Dan
Old Jan 23, 2010 | 04:30 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LSX Swap strut tower brace
The LS1 intake is lower than TPI and TBI
Grab whatever looks better
Keep in mind 3 point STBs have been known to crank windshields and rip the cowl metal under heavy cornering
Old Jan 23, 2010 | 04:39 PM
Engine: LSx 5.3
O wow I didn't know about the 3 point stb's and cracking windshields, thanks
Old Jan 23, 2010 | 09:00 PM
M G Brewer's Avatar
Car: 1988 IROC-Z
well, whats a good system to look at to buy then? any recomendations?
Old Jan 23, 2010 | 09:43 PM
Stephen's Avatar
Car: 87 GTA
The only cracked windshields from 3-pt STBs I've ever seen, were on 4th gens.
I like my UMI 2-pt STB (link to it in my sig).
Get you a TPI STB & if you want it sitting lower, you can trim the tops of the mounts off & drill lower holes for cross bar mounting. I know a guy that had to do that, because of the fiberglass hood he bought.
Old Jan 24, 2010 | 01:26 PM
A10Beav's Avatar
Engine: LS2
Axle/Gears: Moser Ford-9, 3.50
This only happens if you don't center it properly before drilling/bolting it in. I've had a 3 point on my 99 Firehawk for the past 10 years and I've never had a crack.
I have one of these in my '88, although you can probably find it cheaper somehwere else:
http://www.stillen.com/product.asp?i...WR1&c=SU&m=all
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
