computer
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
computer
where are you guys with LTX/LSX motor putting your computers? I saw a pic of one mounted to the firewall, but I want to keep HVAC, so that wouldn't work, mind posting a few pics?
Thanks for the help-
Eric
Eric
Car: '92 RS
Axle/Gears: 4.11
Re: computer
inside of the passenger side subframe rail, just in front of the headers. was honestly the only place i had room and i didn't want to have to extend all of those wires so i could put the pcm inside the car (but i have heard of many guys who put pcm's under their passenger seat or something.
i'm sure it seems like a terrible place, but for the 5 years i've had the swap running, i haven't had a single issue
edit: keep in mind though, i'm using corvette accessories, so if you're using f-body accessories you probably won't have the same amount of room right there
Car: 1987 Trans Am
Engine: LQ9/L92
Re: computer
as Drvng mentioned, many people have extended their wires and mounted it under the dash where the factory one was. Since these computers are meant to be weatherproof, under the hood is definitely an option. Depending on what you've got for wire length, you could mount it where the coolant reservoir is (and run a 4th gen or aftermarket style bottle), relocate the battery to the driver side and mount it on the passenger side tray, or get creative and make a mount for it underneath the passenger side fender (toward the door, not the grille).
rs_z28_vert
Sep 30, 2015 09:47 PM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
