Plugs on underside of LT1 intake - how does LT1 really work?
Old Feb 3, 2010 | 08:08 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I have been trying to clean out my LT1 intake after it was media blasted and powdercoated for over an hr with compressed air and still didnt do it.
I removed the plugs from the underside of the LT1 intake and there was sooo much &*^(*& in there its ridiculous. I am going to wash it all out real good this weekend.
What is the channel behind the center plug for - it has the most crap in it.
The other 4 have two small holes each that go into each runner but not sure what this is for.
I imagine it may be for equalizing pressures and what not.... anyone know how all these really work?
Attached Thumbnails Plugs on underside of LT1 intake - how does LT1 really work?-dscn3657.jpg   Plugs on underside of LT1 intake - how does LT1 really work?-dscn3658.jpg
Old Feb 4, 2010 | 05:51 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Plugs on underside of LT1 intake - how does LT1 really work?
The center hole went to the EGR passage. I forget where the other 4 went. All 5 need to be plugged. Do not plug the narrow slot, it goes to the PCV
I went on a fact finding mission with an old intake I had
Here is my SBC coverted intake
And the spare with the floor removed
Old Feb 4, 2010 | 08:08 AM
Car: 1992 z28
So what did you do here...
you blocked off the factory LT1 intake holes and then you mounted the LT1 over a different intake manidolf in which you had those holes drilled and tapped?
looks interesting, fill me in.
I just found a website for abrasive flow matching which you can use to smooth out your intake to a polished like finish all the way through just just where you can reach with a dremel tool type deal.
looks interesting but very expensive.
http://www.gethoned.com/auto.php
Old Feb 5, 2010 | 05:55 PM
Pocket's Avatar
Car: 91 Trans Am
The old holes were filled and a SBC gasket used to align the new hole locations
The point was showing the plugs and how they needed to be replaced
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
