Intake/Fuel line ?
Car: 1985 Camaro
Engine: 305 ci
Intake/Fuel line ?
Can any of you guys with truck coils and LS1 intakes post pics of how you did the fuel line on the manifold? My fuel line off of the intake is hitting the third coil pack and I can only think of one fix. Also, does anyone know if the walbro intank fuel pump is the same for third and fourth gens? Thanks.
Engine: Cammed 6.0L LSX
Re: Intake/Fuel line ?
I'm assuming the pumps aren't interchangable but someone else may chime in and say differently.
Car: 1989 Camaro IROC
Engine: 6.0 LQ9
I just bent the fuel rail line up a little bit. The pumps should be the same but I'm not 100% on that. I used the Walbro for the 3rd gen.
I used the Walbro 255 for a 3rd gen... I guess the reason why I'm thinking a 4th gen won't work in a 3rd gen tank is because the fuel lines and evap system is totally different? I'm not positive though. I guess an easy way to tell is check to see if the part numbers are the same.
Here's my fuel line after I put the 90* fitting on:
Before with the straight fitting:
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
i just bent mine toward the firewall just a tad bit, just out of curiosity which truck coils are you running? the round ones? or the Mitsubishi ones?
I have LS2 coils and they must mount higher than normal truck coils because I had to bend my line completely vertical. I dont like that at all
My walbro came out of a 4th gen sender. They fit. IIRC walbro uses the same PN for both car pumps, just a different install kit
