LT1 information
Old Feb 24, 2010 | 12:03 AM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
LT1 information
I am swapping an LT1 into my C4 corvette( i know its not an F-body, but i am not getting help anywhere else) I cannot afford AFR heads... Mildly ported LT1 intake/stock iron castings/cc503 cam and matching valvetrain/1.6rr's/gasket match porting/longtube headers and 3" exhaust/52mm throttle body, and a custom tune probably from PCMforless. What kind of numbers would i be looking at? How much hp can i make with this setup with stock heads? Are LT4 heads more worthwhile? I need a cheap alterative to the AFR heads that will perform... I would like to make around the 450 flywheel hp. Any hep would be appreciated! Thanks!
Old Feb 24, 2010 | 12:06 AM
v10viper04's Avatar
Engine: LT1, L99
Re: LT1 information
Is there any glass ceiling for the LT1 heads? How much hp can they support? I would try to do some porting myself but i don't want to make them worse.....
Old Feb 24, 2010 | 04:48 AM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 information
Most HP numbers with that cam and supporting mods have been around 330rwhp.Also don't bother with the LT4 heads nothing special about them.If you want to make 450hp you will need a diffirent cam or a power adder.
http://www.elliottsportworks.com/lt1.html
Old Feb 24, 2010 | 08:57 AM
v10viper04's Avatar
Engine: LT1, L99
Re: LT1 information
Like the cc306? I hear its not too good with stock heads though...
Old Feb 24, 2010 | 03:48 PM
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 information
To get the 450 you want you are not going to be having stock heads.
Mabey stock ported the LE1 kit will get you 400hp+ I would not use the cc306 on stock heads here is another place good with heads http://www.advancedinduction.com/AiProductsLT1.html
Old Feb 24, 2010 | 04:02 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: LT1 information
Search ls1lt1.com, a lot of good research on there, and there was talk of fully P&P Lt1 heads being really good for performance. Nothing will replace money when it comes to horsepower, but the factory heads were pretty stout from my readings. Can't speak on cams, but upgraded valvetrain to LT4 specs were the positive concensus on one of the threads i read.
The same thread also said that unless your P&P LT4 heads, going aftermarket was worth it because of the significant cost of getting the heads put together, and spending a rediculous amount of money on the intake for that little bit extra material around the head area.
Old Feb 24, 2010 | 10:08 PM
v10viper04's Avatar
Engine: LT1, L99
Re: LT1 information
A guy i know that i have gotten both my T-56's from said he can do porting fr me for about $700-900. he says he has dyno proven his port jobs. (he really has been building LT1's for over 10 years) Not a big LS1 guy, likes his LT's. But as far as i see it i might as well wait a little longer and go with some AFR heads..... Am i right?
Old Feb 25, 2010 | 04:48 AM
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 information
You don't have to have aftermarket heads,the stock head responds well to porting. All I am saying if you want 400+hp you are going to have 2 choices port your heads are buy them.IMOP the stock ported is a better than a set of aftermarket.
Old Feb 25, 2010 | 10:47 PM
Firebat's Avatar
Re: LT1 information
You are not going to see much of a difference of aftermarket heads out-of-the-box versus stock ported heads. I wouldn't even consider aftermarket heads on a LT1 unless its a 383 stroker. I believe ported stock heads and a custom cam from either LE or AI is the best bang for the buck.
Old Feb 25, 2010 | 10:51 PM
v10viper04's Avatar
Engine: LT1, L99
Re: LT1 information
anybody here know how to port stock LT heads?
Old Feb 28, 2010 | 05:34 PM
v10viper04's Avatar
Engine: LT1, L99
Re: LT1 information
Old Feb 28, 2010 | 07:46 PM
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 information
It is best to leave it to the ones who know how. You can really screw them up if you dont know what you are doing.
Old Mar 1, 2010 | 10:03 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: LT1 information
I'll give you a ballpark for the numbers you are looking for. I have a '95 LT1 in my '81 camaro with the following items:
6-speed, LT headers with 3" exhaust to the mufflers and 2.5 out, Lloyd Elliot Stage 2 heads and cam, computer tune, 36lb injectors, 58mm TB, slightly ported intake, and a completely stock bottom end. This has given me a dyno of 362hp/365tq at the wheels.
My '86 also has a '95 LT1 with a CC305 cam, crappy flowtech headers into a flowmaster cat-back, 6-speed, stock heads, stock intake, stock TB, and a completely stock motor. This dynoed at 280hp at the wheels with a 700R4 trans. I haven't gotten it retuned for the 6-speed.
Hopefully this will give you a decent ballpark. If you want some decent HP you will have to work on the heads. Stock LT1 heads can be worked to flow very well by somebody who knows what they are doing. I would highly recommend Lloyd Elliot. Is it priced pretty good and he will talk to you about exactly what you want the motor to do and work the package accordingly.
Old Mar 1, 2010 | 10:06 AM
1981LT1's Avatar
Engine: LT1; LT1
Re: LT1 information
I ran the CC306 for years in my '81 camaro. You cannot use this cam with stock heads since it requires stiffer springs and a machine shop will have to cut the spring seats bigger. That cam is awesome for a 6-speed but was an absolute dog under 3K rpm's. Don't just get it becuase people say it is great for HP. You need to match everything and you will be much happier.
Old Mar 1, 2010 | 12:42 PM
v10viper04's Avatar
Engine: LT1, L99
Re: LT1 information
Well i would be changing the valvetrain anyways. I'll get a hold of elliot. Thanks for the numbers you posted.
ZEEYAA
Apr 16, 2023 08:29 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
tmellott89
Oct 14, 2015 02:06 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
sahlomonic
Sep 20, 2015 07:15 PM
