please help! 2003 corvette ls1 into a 90 rs
Old Apr 1, 2010 | 10:56 PM
pyrocuervo's Avatar
Car: 1990 rs tbi soon to be lsx
Engine: 305 soon to be ls out of a 03 vette
Transmission: 700r to be 4l60e
Axle/Gears: stock to be posi
Help!!!
I'm getting a 2003 ls1 out of a corvette with under 30,000 miles on it. it was rolled. the seller is claiming that the engine is still stock internally, he did not open it and good. with new intake manifold and throttle body with 24# injectors. minus oil pan and accessories, with the exception of the water pump. will include engine, water pump, coil packs, wiring harness and pcm. drive by cable throttle since it's a drive by wire stock.
I am a total newbie to ls engines!!
I want to keep my 700r that will be rebuilt, help with that as well if you can.
i want to keep power steering, and my stock a/c??? I 'm not getting the interior dash so I don't know if it's better to get a 4th gen or i can make this work and look stock? please any and all help appreciated, i know i have to upgrade my fuel delivery system as well but don't know the best route? adapter for the tranny? k member needed? btw, all steering components on my 90 rs are new.
Old Apr 1, 2010 | 11:00 PM
pyrocuervo's Avatar
Re: please help! 2003 corvette ls1 into a 90 rs
also forgot to mention, engine is going to cost me $1900 so I'm trying to spend hopefully as little as possible for everything else maybe a $1000 budget? hopefully less.
Old Apr 2, 2010 | 01:34 AM
kizmaro89's Avatar
Car: 89 Camaro RS
Engine: LM7
i dont think you can use the drive by wire TB with a 700r4. The DBW throttle body won't have a place to hook up the TV cable. Stock k-member will work but you'll need to notch it to use A/C.
Old Apr 2, 2010 | 02:05 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
$1000 budget...yea no way
Old Apr 2, 2010 | 07:16 AM
Pocket's Avatar
Car: 91 Trans Am
I remember a thread on LS1tech about a guy who used a TH400 with DBW and retained kickdown. The cable was mounted to the pedal and operated in the same manner as one mounted to the TB. Pretty ingenious. I wouldnt count out a 700R4 just because its DBW
$1000 budget is too small, and $1900 for a LS1 long block is too high. Generally you can get the engine/trans combo for that from a Fbody
Old Apr 2, 2010 | 07:53 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
TH400 uses an electric kickdown instead of a cable like the TH350, if it were me, I would put the 4L60E behind it, you can find one for what you would end up have in rebuilding the 700 you have.
Old Apr 2, 2010 | 08:23 AM
Pocket's Avatar
Car: 91 Trans Am
Ok, it was a TH350, I remembered wrong
http://www.ls1tech.com/forums/conver...bw-thread.html
Old Apr 2, 2010 | 10:04 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
This is correct. 700r4 wont work correctly, or last very long without a properly working TV cable. It controls line pressure. I would find a 4L60E, as Klortho stated. It's an electronic controled, and updated version of the 700r4. Dean
Old Apr 2, 2010 | 10:42 AM
screeminchicken's Avatar
DOnt forget the DBW pedal and its harness too. And ya instead of rebuilding the 700R4 (4L60) get a 4L60e
good luck
Old Apr 2, 2010 | 11:05 AM
pyrocuervo's Avatar
thank you guys for your imput!
about the tranny I prob. will have to trade up, I was hoping to keep it since I have a guy to do the rebuild really cheap. 1900 is high but i liked it since it came out of a corvette-aluminum block, and carfax i got today showed 12,000 miles on it. it was a movie car that got rolled in the last scene. i was just hoping for a 1000 budget, but it's more like 2000.
any other tricks or shortcuts that might benefit me?
Old Apr 2, 2010 | 11:24 AM
Pocket's Avatar
Car: 91 Trans Am
Corvettes and Fbodys got the same LS1, year to year. There were a few differences but nothing worth the vette tax
Tip on shortcuts, dont take them. Do it right or do it twice
I would highly recommend replacing the oil pump before putting the engine in too
Old Apr 2, 2010 | 03:22 PM
pyrocuervo's Avatar
i guess i didn't make it clear. I'm using the drive by cable not by wire. either way, I am looking for a 4L60E instead of rebuilding my 700r.
Old Apr 2, 2010 | 04:31 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
easier to find a ls1 fbod 60e. alredy has the tq arm mount
Old Apr 5, 2010 | 09:45 PM
pyrocuervo's Avatar
ok so i have:
-2003 vette ls1 no accesories execpt water pump.
-new intake/ throttlebody/ fuel rails
-coil pacs
-24# injectors
-wiring harness/pcm
-stock exaust manifolds/headers
-found a guy that claims to have a 4l60e out of a special edition ws6? borg wagner edition? with only 800 miles on it, car was wrecked new. any imput?
still need new driveshaft, and prob. new rear end. hopefully I can find a cheap posi. or just keep the freeway gears for better fuel milage.
Old Apr 5, 2010 | 11:05 PM
Pocket's Avatar
Car: 91 Trans Am
None of the low production 4th gens had any different trans than the rest
Your stock DS will work fine, or use a 4th gen piece. 84-02 interchange freely
Old Apr 7, 2010 | 09:01 PM
pyrocuervo's Avatar
thanks! I'l prob just use a posi or rebuild the stock diff to keep fuel economy a lil higher. less fun but helps out in the wallet wouldn't it? I also have all the sensors(forgot to mention that) to the engine. how can I keep/make this smog legal in california???? I would really love that instead of paying the 150-200 every two years.
Old Apr 7, 2010 | 10:09 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
There have been a couple smog legal California swaps here on thirdgen.org - use the search, it will definitely help.
Old May 18, 2010 | 01:04 AM
pyrocuervo's Avatar
I was hoping to keep my stock ac since it works fine, anyone know where i can get the custom bracket to keep my ac with the ls1???
Old May 22, 2010 | 12:00 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
There is a conversion that has been shown on here. The problem with the 'vette engine is the accessories are mounted 3/4" closer to the engine. Space in our cars becomes limited. That 3/4" puts everything back into the engine, or the suspension.... The conversion you were asking about was surely made for the F car engine only, as there seems to be not enough room to put the compressor there with the C5 setup. The back of the compressor on the C5 version, wants to be in the same space as the front of the right side A arm. Guess who gets first dibs? ;-)
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
