2.8 v6 to LT` radiator what to do?
Old Apr 14, 2010 | 07:49 PM
kukerdan's Avatar
Hi, I see I am supposed to use a v8 rad, but that lt1 is reverse cooled... so does that mean the radiator in/out are o different sides?Can i just get a rad out of a thirdgen v8? and use custom hoses?
what about my rad? its pretty puny...
what about a 4th gen camaro rad/fans... will it bolt up?
thanks so much
Old Apr 14, 2010 | 08:24 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: 2.8 v6 to LT` radiator what to do?
You can use a V-8 3rd gen radiator, the hoses are 95 camaro z28 upper and a 87-93 mustand 5.0 upper for the lower.
The 4th gen radiator will bolt up but you will need some brackets it leans forward a little.The fans will work with a 3rd gen radiator.
Old Apr 14, 2010 | 09:39 PM
Pocket's Avatar
Car: 91 Trans Am
Use whatever radiator is in there unless you just want to swap it. Reverse cooling means the cyl heads get cooled first instead of last with the standard SBC. It has no bearing on radiator usage
The main difference is the water outlets are funny on older V6's. Using a V8 or 90-92 V6 (same as a V8 rad) puts the outlets in the standard SBC locations and you can use the normal hoses associated with LTx swaps
Old Apr 26, 2010 | 10:41 PM
kukerdan's Avatar
wait, so my 88 v6 rad is good enough?
Old Apr 26, 2010 | 11:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 3.1 V6 version, yes. But, not the 2.8 V6. It's smaller, and has the inlet/outlet on the opposite sides.
Old Apr 27, 2010 | 12:02 PM
kukerdan's Avatar
k thanks
michael
South Central Region
Dec 18, 2002 04:10 PM
KED85
Jun 25, 2002 10:56 PM
ChrisFirebird
Nov 16, 2001 02:56 PM
kizz
Sep 10, 2001 07:38 PM
