4L60e experts chime in please
Old May 22, 2010 | 04:52 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Ok, guys I have a delimma that I need some serious help with. I have a 1999 Tahoe 5.7 4L60e (late) with the 2-piece bellhousing and six bolt tailshaft. I thought it was from a V6 astrovan, but confirmed it was a 99 tahoe 5.7.
I recently found out that since this transmission was on a Gen II vortec engine it uses the older style input shaft. I call this a hybrid because it looks like the 1998-and up F-body and 2000+ Truck tranmsissions but has a mix of old in it because of the input shaft.
In order for this to bolt to my 2004 Vortec Gen III engine I needed to purchase the GM spacer and longer bolts for the flywheel.
I started the installation earlier and noticed that when I tighten my tranny to the engine, the torque converter is binding against the flex plate....now before you say that my TC isn't in all the way, it is- I double checked it. No sheared pumps here
I loosened the bolts and backed the tranny about 1/8" away from the block and installed my flexplate bolts, but when i tighten the bolts down it binds up again....I can't even turn my engine at the harmonic balancer.
So my question is, is it possible that there could be some bellhousing variations between the early one-peice 4L60e tranny and the later two-piece 4L60e with the old style input shaft?
Maybe I didn't need the spacer since it was a V8 tranny?
Need some help with this and any guidance would be great.
Old May 22, 2010 | 05:32 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 4L60e experts chime in please
A fully seated TC that binds when the bellhousing is bolted to the block means the flex is too close. Lose the adapter
When you bolt it on the next time check how much the TC needs to pull forward to bolt to the flexplate. Newer trans seem to be much tighter than older ones as the TC should be 1/4" or so away from the flex when fully inserted into the pump
Old May 22, 2010 | 08:34 PM
jackaharmon's Avatar
Car: 1989 Pontic Trans Am GTA
Engine: old 350TPI/new LS1
Transmission: old 700R4/new 4L60E
Axle/Gears: 3.27 stock
i have a feeling that the torque convertor is not fully seated in the transmission, but i have been wrong before...
djmarch
Oct 2, 2015 10:41 PM
ASE doc
Sep 22, 2015 03:13 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
Ranbo108
Sep 9, 2015 12:20 PM
