LT1 fuel problem
Old Jun 3, 2010 | 05:28 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
LT1 fuel problem
I am helping a buddy with a swap and he put a new fuel pump in it (walbro).
It has no FP at the regulator put a new one on, but it will push the gas up to the intake.
My question is could he have wired it up backwards and it still push gas and have no pressure? We can get it to run off started fluid though.
Old Jun 3, 2010 | 09:31 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: LT1 fuel problem
No, wired backwards it wouldn't be able to pull fuel since the return line is not stuck inside the fuel, just dumps in the top of the tank. It's possible the regulator is bad.
Old Jun 8, 2010 | 05:43 PM
Car: 1992 camaro
Axle/Gears: 3:73
Ok over the weekend we put a regulator on it still nothing. He has around 65-70 psi on the feed line. But dose not have nothing after the regulator any other ideals?
Old Apr 2, 2011 | 08:58 PM
formula 89's Avatar
Car: 89 formula,92 firebird
Engine: 91 355 tpi, 3.1
Transmission: 700 R4
Axle/Gears: 342 posi,
maybe someone can help me,89 formula, lt1, ran when parked two weeks ago, just put new fp in and still wont start, but will start off starting fluid. good pressure at fuel rail, but will not start on its own free will. anything simple to check?all injector fuses are good so im cluless, guess its in the comp
Old Apr 2, 2011 | 09:50 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Check the injectors, make sure they are firing
92camaroJoe
Jul 29, 2023 07:57 PM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
sreZ28
Aug 14, 2015 07:48 PM
92camaroJoe
Aug 13, 2015 06:07 AM
