How much to keep and how much to get rid of with a LS1 shortblock?
Old Jun 10, 2010 | 03:18 PM
CamaroIROC88350's Avatar
I found a LS1 engine with everything assembled (except the camshaft) for sale and it had 89,000 miles on it from a 98 Trans Am. I was wondering if I wanted to buy this for my IROC how much of the original parts could I keep in my Z now & how much would I have to change out to accommodate the LS1? I love my TPI but for $400 you can't beat that kind of deal for a LS1.
Old Jun 10, 2010 | 03:26 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: How much to keep and how much to get rid of with a LS1 shortblock?
anything and everything engine related will have to be replaced, including accessories, brackets, wiring, ecu, etc. new exhaust will be needed forward of the cat (minimum). and a new fuel pump/regulation system.
short and sweet list
Old Jun 10, 2010 | 04:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is a reason these are commonly sold as "drop outs", which include engine (longblock, not just shortblock, and with all accessories, intake, throttle body, fuel rail & injectors, etc.), harness, PCM, and transmission.
By the time you buy all of the missing pieces to make that engine run, you most likely could have bought a drop out for less money.
Short & sweet TPI to LS1 swap procedure:
Step 1) Remove all of the TPI engine, transmission, harness, and ECM stuff.
Step 2) Put the LS1 stuff in its place.
Old Jun 10, 2010 | 04:44 PM
Pocket's Avatar
Car: 91 Trans Am
$400 for a shortblock? Fair price assuming it has the Fbody oil pan
No pan, no deal
Old Jun 10, 2010 | 06:20 PM
No pan, no deal
Now it's $350 on Craigslist! It comes with the pan I assume because the only thing this guy says it doesn't come with is the camshaft. It's off a 99 Z28 too. I made a mistake with it being a Trans Am.
http://stlouis.craigslist.org/pts/1771400058.html
Old Jun 10, 2010 | 07:21 PM
Pocket's Avatar
Car: 91 Trans Am
Go check it out and see
Old Jun 10, 2010 | 08:51 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I got a long block with a FAST intake but no pan or accessories, harness ECM, sensors or anything. I have nickle and dimed myself to death. Get a complete pullout. I highly suggest it.
Old Jun 10, 2010 | 09:50 PM
five7kid's Avatar
Sounds like a bare shortblock. Doesn't have heads. A few of the valve train pieces are being thrown in.
Old Jun 11, 2010 | 07:19 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
agreed, there's a lot missing to get this thing to even start. i picked up an LS1 long block for $500, but ended up grabbing a 5.3 since it had everything (sensors, harness, ecu, etc). this would be a good deal if you already had everything and wanted to work over a block without having to pull your current one
Old Jun 11, 2010 | 08:09 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I disagree with all these guys on this one. Those blocks sell for like $1100 new, and that's just for a bare block.
They're right about also grabbing a complete truck LM7 or LQ4 to get everything else from. The LQ4 heads would be better. If you're gonna stay away from adding boost, then LQ4 heads would need to be milled about 0.025" to maintain compression.
Old Jun 11, 2010 | 08:32 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I've got an assembled set of LS1 heads I would sell you for a reasonable price and I am local.
Old Jun 21, 2010 | 11:58 PM
I'd like to take a look at those and we can discuss the price & specs on them too. Thanks Nick.
skinny z
Oct 5, 2015 06:23 PM
dusterbd
Sep 29, 2015 08:40 AM
