LT1 valve covers
Old Jul 5, 2010 | 06:53 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
LT1 valve covers
What are you guys doing as far as PCV valves and breathers go? I have the canton valve covers and one side has the oil fill cap and the other has an open hole. I was thinking of using a K&N breather on this. Should I or should I not do this and go with a PCV valve? If i go with the breather how do I plug the large port in the LT1 intake?
I am also not running a vacuum line to the brake booster so I can plug this as well.
Old Jul 5, 2010 | 08:42 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 valve covers
Id keep a PCV system in place
Engines have an inlet and outlet for the PCV system. Inlet lets fresh air in (metered for MAF cars) and outlet drawing the dirty crankcase gasses and misted oil out using the manifold vacuum. Generally the in/outs are on opposite valve covers, but GM moved the outlet from the drivers valve cover to the intake base (lifter valley area) for tighter packaging
To run a breather you need to either plug this and cut a hole in each valve cover or run a breather to one and another breather off an extension going to the intake port
FYI, breather systems are notorious for misting down engine bays with oil over a short time
Old Jul 5, 2010 | 09:16 PM
Car: 1992 z28
Thanks Pocket. If there are no benefits to the breather then I can pass on it. My setup is a 383 LT1 with a D1SC procharger so dont know if this makes a difference either.
Now I need to find where to get a new or used PCV setup. Any ideas?
I'll check ebay now.
Old Jul 5, 2010 | 09:38 PM
Pocket's Avatar
Car: 91 Trans Am
Check a dealer for the formed rubber tube on the pass cover. You can substitute oil safe rubber hose, it just doesnt fit as clean. The port fittings and PCV itself can be had for around $2 from any local parts store
Id suggest a catch can system with multiple check valves for the blower. Dont need to be blowing the dipstick out
Old Jul 6, 2010 | 05:55 AM
Car: 1992 z28
Pocket - I am not familiar with the catch can setup and check valves. Would you mind explaining this some more? I will def. be doing research on this before I get the blower installed.
Old Jul 6, 2010 | 08:09 AM
Pocket's Avatar
Car: 91 Trans Am
Catch can is a term used to describe automotive air/oil separators used in line with the PCV system to cut down on oil in the chambers. This cuts down on detonation in more picky builds
Generally these are simply a shiny can with ports welded to it, sometimes they also come with internal baffles and coils to better separate the fluids
Check valves are one way valves preventing the gasses from moving the opposite direction in the PCV system. Since the system only operates during idle where the engine will be under vacuum, these keep reversion from coming in when your turbo builds boost
Old Jul 6, 2010 | 10:56 AM
Car: 1992 z28
Interesting.... any idea where I can get one? and/or who makes the best one? O would rather put it in now - sounds like this can only help and not hurt you, wonder why i dont see anyone using it... just a money thing?
Old Jul 10, 2010 | 11:31 AM
Car: 1992 z28
ok, i am making this harder than it needs to be, I was mistaken above, this is what i have now:
Canton valve covers with the drive side valve cover having no holes in it. it is sealed.
The passenger side has the oil fill cap and a hole. Does a PCV go into this hole and to any hole into the intake? or a specific hole?
There is a large hole on the driver side of the intake. Does a pcv go into this as well?
confused myself now... because is there 1 pcv? and if so which place does it belong and if two then am i right above?
attached are pics of what i have now. one PCV installed in intake and I was thinking of just running a U-shape hose to the hose connection just to the right and above the PCV
i put a grommet in the passenger valve cover but not sure what to do now.. lol
I appreciate the help.
Attached Thumbnails LT1 valve covers-dscn5517.jpg   LT1 valve covers-dscn5518.jpg   LT1 valve covers-dscn5520.jpg
Old Jul 11, 2010 | 10:55 AM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
Nasty looking motor you have there
Old Jul 12, 2010 | 07:45 AM
Car: 1992 z28
Haha,
Now I just need to get these odds and ends done so she can run!!
Anyone got info on the above post for PCV and crank case venting?
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
