? on an LT1 swap
Old Aug 18, 2010 | 09:17 PM
jwright32's Avatar
Engine: Lt1
Transmission: TH400
Axle/Gears: 4.11
? on an LT1 swap
On an LT1 the temp wires coming from the computer are available, but not hooked up. I was told they are active wires. For me to use the wires would I just need an electric gauge to tie into the wires? (ones engine temp and other is oil pressure) Any knowledge is appreciated.
Old Aug 19, 2010 | 09:21 AM
Pocket's Avatar
Car: 91 Trans Am
Re: ? on an LT1 swap
The PCM doesnt control the oil/coolant wires on any GM engine
Run them direct from your old C100 wiring with the newer connectors to fit the LT1 sensors
Old Aug 22, 2010 | 04:46 PM
jwright32's Avatar
Engine: Lt1
Transmission: TH400
Axle/Gears: 4.11
ok thanks again, pocket
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
