Shes ready to fire up!!!
Old Sep 13, 2010 | 01:28 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Finally got everything I need in the car right now to get it going. My buddy is going to throw a quick tune on the 411 tomorrow and we'll see what happens on wed or thursday. Anything I should look for when firing it up?
While I was add it I got a little older and wiser and threw back in the ac. It was out for the last 10 years but I kinda like it cool lol. Its TIGHT in there. Clears the truck coils by about 1/4 inch.
Gotta make a nice CAI for it , but I'm not that worried yet. I'm running a SD only tune for now. I wired in a 5 wire maf connector though JIC. I'm running an external IAT.
Attached Thumbnails Shes ready to fire up!!!-001.jpg   Shes ready to fire up!!!-002.jpg   Shes ready to fire up!!!-003.jpg
Old Sep 13, 2010 | 01:59 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Re: Shes ready to fire up!!!
I'd keep an eye on your coolant level and coolant temperature, you may have to purge it. Also keep an eye on the fans and make sure they come on at the temperature that you have them set at in your tune and don't forget to fill the power steering reservoir or else it will whine at you. I have a Tech II so I was able to manually turn on fan 1 and fan 2 so that was pretty neat. Keep an eye out for any oil, coolant, or fuel leaks. Car looks awesome man, good job
Old Sep 13, 2010 | 02:51 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I could not get the car coils to clear the AC box, only the truck coils would.
Old Sep 13, 2010 | 06:12 PM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
I've read a lot of threads regarding car coils hitting and truck coils clearing but I have not been able to find any related pics showing exactly what the interference with the a/c box is and why the truck coils clear. Do you have any up-close pics of your clearance you can post? I'd be appreciative.
Mike
Old Sep 13, 2010 | 06:21 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Here you go, i broke a truck coil and used a car coil temporary and it is in the back in this pic, you can see how the truck coils mount the wire lower, the car is higher, where the car coil mounts the wire you cannot get a wire on because it sits against the AC box and there is no way to make it work otherwise without some fabrication.
Old Sep 13, 2010 | 06:55 PM
mwfrels's Avatar
Car: '86 Z28
Transmission: WC T5
Okay, I believe the fog is beginning to clear. I went digging for some images so I could verify.
If I understand correctly from what you said and what I can see of that temporary #7 coil on your car the car coil's wire tower sit taller away from the valve cover as it looks here:
But the truck coil wire tower is lower next to the cover as these appear:
Yes/No?
Mike
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
theres about 1/4 in between .
Old Sep 13, 2010 | 07:04 PM
mwfrels's Avatar
Car: '86 Z28
Transmission: WC T5
Looks like they are close at the lips that are the mating seal surfaces of the top to bottom of the housing?
Mike
Old Sep 13, 2010 | 07:13 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Yea
Old Sep 13, 2010 | 07:17 PM
mwfrels's Avatar
Car: '86 Z28
Transmission: WC T5
BTW I apologize for the hijack. I was gawking at the clean engine in that clean white engine bay and imagining that mine will look similar If I do all my homework and take the necessary time to do it right. My Z28 is white and A/C is mandatory so I want to have this clearance issue taken care of before install day. That is what prompted the question and deviation from the thread.
Nice looking install. Congrats...
Mike
Old Sep 13, 2010 | 07:22 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Antime. Thats what were here for. Its a TIGHT fit lol. But it all fits.
Old Sep 13, 2010 | 07:24 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Any for anybody wondering. Firebird pos and neg cables fit perfect. Accually too perfect lol.
Old Sep 13, 2010 | 10:13 PM
Pocket's Avatar
Car: 91 Trans Am
The second set of coils posted are the LS2 coils. Cars and trucks used them. Ive got GREAT clearance all around with them and I think they look the best
+1 on the 3rd gen cables fitting PERFECTLY. I like the Lo3 cables because they're larger and dont have any extra connectors sticking out like the V6/TPI ones do
On the initial start, make sure you've got oil in it (almost forgot that tonite). If the fuel system primes you should be golden. Remember to keep and eye on the temp gauge, LSx are sometimes fussy about air in the system
Old Sep 13, 2010 | 10:44 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Oh it primed. I disconnected the fuel rail from the fitting and put it in a jar. Took about 4 tries of the pump going and then fuel came out with some junk. Spitted then a nice stream. I figured, might as well clean out the lines from working on them and so forth. Then installed the line and primed and bled them out though the bleeder. some puffs of air then all fuel. I cranked it tongiht with the packs disconnected and it cranked over fine. Both coils have power to them when the ign is on so thats good. IAC moved when I turned the ign on so thats good. I have to take the pcm tomorrow to get an initial tune. Only tune on it now was when I had my 383 OBD II running on the express van tune for SBC's.
Old Sep 14, 2010 | 06:41 AM
mwfrels's Avatar
Car: '86 Z28
Transmission: WC T5
That tells me clearance won't be a problem then...
In case anyone is wondering there is now an LS2/T56 sitting in a corner of my garage. Been there for the last month actually. I am in the early stages of project process planning. I will be starting a thread on it soon.
Mike
Old Sep 14, 2010 | 08:57 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
IT STARTS AND RUNS !!!!
I got back today from teh guy throwing a tune on teh ecm just to get it going. Install it and turn the key and it instantly starts then died after 5 seconds. After it died I hear a ton of fluid hitting the garage floor. I'm like WTF.... I get out and I forgot to attach the rubber line to the tranny cooler. Nice 50 gallons of Dextron 6 on the round. I install that and go to fire again. Again, it dies after 5 seconds. The i get a wiff of a ton of gas.... Not good. Check all my braided lines. No issues. Here, the number 1 injector was leaking like mad where it attaches to the fuel rail...... Everything is new so I was shocked. ripped out that Injector and O ring and threw in a used O ring from my TPI injector I had laying around. Tossed it back together and she idles nice. Loud with open headers but It starts on a dime... I'm happy.
Old Sep 14, 2010 | 09:33 PM
Pocket's Avatar
Car: 91 Trans Am
The first start is an awesome feeling of accomplishment. Dont feel bad about the trans line, everyone forgets a little thing or two on the first start
Old Sep 15, 2010 | 05:53 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Perhaps a slightly off topic question, but do you know if it's possible to put the a/c box on the car once the engine is installed using the truck coils? I have often wondered about that, as I have contemplated putting a/c on my car, and I'm using the truck coils. I know it would be a super tight fit, but wasn't sure if it's possible to get it in with the engine in the car.
Old Sep 15, 2010 | 08:40 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
oh it fits fine. i did all my ac when the engine and everything in.
Old Sep 15, 2010 | 10:14 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Hell, on a 383 i had, friend of my didnt put the oil filter on like he was told to by me, started, no oil pressure, killed it then saw the slow mass spread from under the car, LOSE. LOL
Old Sep 16, 2010 | 07:18 PM
clippjr8's Avatar
Looks good matt. I love the attention to detail. Cant wait to see what it makes on the dyno. You will be glad you did the swap. Im also wondering how the MPG will be. Enjoy it.
Old Sep 16, 2010 | 07:58 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Couldnt have done it without you!!
PurelyPMD
May 5, 2016 04:57 PM
89bird2.8
Sep 18, 2015 07:46 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
