HELP! replaced timing chain now no start!
Old Sep 15, 2010 | 10:32 AM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
i recenetly replaced the timing chain on my 95 LT1 motor that i have in my 87 trans am.when i replaced it i just ligned up the marks and put it back together,but i didnt check to see if it was at top dead center.
From what i remember there are 2 rotations of the crank and only 1 of the cam correct?
im also hoping that i didnt do any valve damage turning the crank without turning the cam too...HELP would be great!
Old Sep 15, 2010 | 10:50 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Re: HELP! replaced timing chain now no start!
Did you make sure it was at TDC before you took the old chain off?
Old Sep 15, 2010 | 11:05 AM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
No,and that's the problem I think...I ligned the marks up after I took the chain off,which I now realize is what your NOT supposed to do
Old Sep 15, 2010 | 01:01 PM
pwdbychevy's Avatar
There is the problem. Timing is way off. Set to TDC and THEN align the timing marks on the sprockets. You should be good then.
Old Sep 15, 2010 | 07:29 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
Wow and now I feel real dumb,went out today to start tearing it all part again and found that my coil wire was unplugged.I plugged it in and it fired right up! Thanks for your help though.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
MY87LT
Aug 17, 2015 08:43 AM
86Base
Aug 8, 2015 01:34 PM
