LS3 Swap from 5.7 TPI
Old Oct 23, 2010 | 09:59 PM
WorldxTxFailure's Avatar
I recently got a 1987 Iroc with the 5.7 TPI. Instead of modifying it, I'm maybe thinking of going with an LS3 setup. I've been searching the web and have found the E-rod LS3 kit with:
LS3 Production engine
Controller
Harness
Exhaust Manifolds
Catalytic Converters
O2 Sensors ( Four Pieces )
Dry Air filter Element
Fuel Tank Evaporative Emissions Canister
Air Flow Sensor
Electronic Accelerator Pedal
Then I have found the maddog 4L80E tranny that they say can hold up to 1200HP. Although if possible I'd like to find something a little cheaper. Maybe a used one.
I also think I will need this:
http://www.crateenginedepot.com/stor...6-P1734C0.aspx
Besides all this stuff, what else will I need to make the swap and were can I find it?
Old Oct 25, 2010 | 10:47 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: LS3 Swap from 5.7 TPI
welcome aboard! check out the stickies at the top of the forum, they'll have all the info you need on the swap (overall pretty much identical to an LS1 swap).
there's a bunch of build up threads in here, so just take some time and read through to see what others have run into. the big stuff's easy to account for; its the small stuff that'll kill ya and your wallet.
Old Oct 26, 2010 | 07:32 AM
mattmerritt89's Avatar
Car: 1987 Camaro
Axle/Gears: 4.56
Controller
Harness
Exhaust Manifolds
Air Flow Sensor
Yeah the erod engine is really good I was thinking of going the same route. it has everything needed for a swap, and you come out to about the same price as doing the swap buying a part at a time. and if you have emission testing in your area it will pass.
Frozer!!!
Jan 19, 2024 04:55 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
gta90
Sep 15, 2015 04:00 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
