TPI Serp setup on LT1
Old Oct 30, 2010 | 11:01 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Has anyone used a third gen sertantine setup on an LT1?
I currently have a '92 serp setup with A/C and air pump delete pulleys. I know with the LT1 you would also not need the the water pump pulley. So now you're left with the crank, alt, p/s, an tensioner, and the delete pulleys if required to get a good routing.
Reason for my thinking is I would rather use the third gen p/s pump over the 4th gen one that I know have issues at high RPM's.
Old Oct 30, 2010 | 12:50 PM
Pocket's Avatar
Car: 91 Trans Am
Re: TPI Serp setup on LT1
First, they dont bolt on
Second, get a smaller pulley if the pump gets spun too high
Old Oct 30, 2010 | 02:35 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
No, the brackets wont fit without a TON of cutting. then you have the LT1 water pump in the way issue.
I made the D.side sept. bracket work on my LT1. but just for a spacer for my novi 2000 supercharger bracket/build.
The novi came off a TPI setup and was made to fit with stock Accessories. instead of making a new bracket n spacers , etc.. I made the Serpt. bracket work for now.
but it would have been to much of a hassle to try and make the serpt. setup work with alignments, etc....
Old Oct 30, 2010 | 04:49 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Darn, thanks guys. I looked at my LT1 on the engine stand and th TPI in the car and there does seem to be quite a difference in the spacing between the block and the belt.
Sucks in that I bought a new alt and p/s within the past two seasons for the TPI, now I'll just have to hope the LT1 alt is good and go buy a Turn One p/s pump.
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
