So Cal member gets “attacked” for planning LS1 swap
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: So Cal member gets “attacked” for planning LS1 swap
This thread made me Ell Oh Ell. Dyno Don posted some crap in my build thread about his stance on an lsx swap and nobody in my thread provoked him. So to that, I'd say **** off...I will continue to put these motors in these cars, even the rarer more saught after models, and I don't care if any purists think it's an obomination.
Here's MY stance on this argument:
If I could have taken a stock cube, stock heads, stock intake TPI motor and put am aftermarket camshaft in it and put down 420/407 to the wheels on a dyno, I would have done it. But that is physically impossible and every TPI purist knows it. So as it sits, I'm at a good 100+ rwhp more than a cam only L98 and as soon as I mod it more that gap is just gonna get bigger.
I can't wait to see where my top end installed on top of an 11:1 406 will put the power output. A similarly modded LSx should get ahead, but it won't get away.
Engine: Cammed 6.0L LSX
I don't think my point was very clear. The beauty of the LS platform is I don't need 406ci to make monster power. I will be able to reach the 500rwhp mark with stock cubic inches (364). With better heads, intake, throttle body, and if need be a slightly different cam, I will be at a power level you can only get with much more cubes or a big shot of nitrous with a traditional small block.
"If I could have taken a stock cube, stock heads, stock intake TPI motor and put am aftermarket camshaft in it and put down 420/407 to the wheels on a dyno, I would have done it. But that is physically impossible and every TPI purist knows it. So as it sits, I'm at a good 100+ rwhp more than a cam only L98 and as soon as I mod it more that gap is just gonna get bigger."
Yes, we get it. You don't have to pass California Smog.
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
I want to see a stock bottom end TPI with just H/C/I run 9.5 in the 1/4th, and be driven to the track.
Burnout: So your 406 is going to make at minimum 550 to the rear wheels like a properly setup 408 iron block and still be streetable?
If I was selling parts for a platform that was dying out I would be trying to convert as many people back to it as possible(cough)... or move to the better platform.
Or just go BBC. BBC > all.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
"You can pass smog with an LS swap. There's hundreds of swaps done in California that pass smog. "
I agree you just have to go through the hoops.
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
These conversations make me want to go LSX. Decent power with just a cam swap and amazing mpg is not arguable to me.
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Yes, installing a LSin CA does require dealing with the ****'s, but they have no way to disallow when a complete stock LS is transplanted. With a modded TPI you better have all your EO stickers and any visible welds etc might be hard to explain.
I have no way of running the numbers, but a used LS rebuilt and installed can't cost as much as all the legal after market parts to get almost the same HP from the TPI
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
1. TPI is better than LSX...Really? so thats why GM still builds cars with TPI then?
2. It’s cheaper to make power with a TPI build vs. LSX build...no its not
3. LSX in 3rd gen is “bastardizing” your 3rd gen...you owning a 3rd is bastardizing ever 3rd gen out there
4. Only TPI motors belong in 3rd gens...thats why some came factory with carb and TBI?
5. LSX in 3rd gens look ugly...so does your girlfriend
6. LSX swap cannot be done in your driveway...oh man really? i guess i didnt do mine in my driveway after all! it must be some kind of new open air shop idea i came up with
7. TPI can get comparable MPG’s to a LSX and even better...i would like to see that.
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Atilla built a stroked TPI motor that built power until something like 6 grand if I remember correctly. I wanna say it was like 480 horse and 530 ft lbs.
I'm not saying I'm a fan of the TPI, personally I have never owned one but my god I don't think you can compare that to an LSx. In stock form the LS heads outflow many machined first? gen heads.
And as far as a sleeper goes, it doesn't matter what is under the hood. Everybody I have ever raced has never seen under my hood. When my car was bottled the only people who knew were my dad, my brother and my best friend.
Engine: Modded L98
Maybe my point wasn't very clear: Any engine can be modded for increased output; bickering over the number of parts required to do so is pointless, it is the end-game power level that will be used to measure the success. And, there is always at least one more part or idea to throw at the given motor.
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Can anyone really argue the point if they haven't done both? It seems like the only way to get a good comparison is to build and drive a tpi car and then build and drive a lsx car. For the people that have done both I don't think they're ever going back to a tpi.
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Cant do the swap in the driveway??? Thats just a stupid argument. I dont mind the technical back and forths about each motor...but if people are throwing around things like that just to make the "anti-ls1 list" longer, than thats pathetic.
Ive done it TWICE...
Oh yeah...and the second time the motor went in IN THE DARK...
OMG the ugly cobbled together hideousness of it all!!!
Oh...yes a TPI can get comparable MPG to an LS1 swap... Yes it can make similar power. But I dont think either of those are easy to obtain at the same time... or without the use of a T56...which by the way guys...isnt a stock item on a thirdgen. So if you are swapping that in, chalk that up to the bastardization.
I dont like getting into the TPI vs. LS1 debate usually. Ive had both. Both have their pros and cons. If I were to purchase a VERY clean GTA...Ide probably leave it alone. I just hate the stupid arguments. But after driving my LS1 car for as long as I have...I would NEVER go back to a TPI for a daily driver or race car. Just a personal stance. My love of thirdgens keeps me from ever telling someone else their motor choice is wrong or stupid. Its all the same game folks.
J.
J.
Car: RS
Axle/Gears: 9" for the ladies
These threads make me laugh.
I'm just happy I live in the LSx center of the world here in STL, where we were doing ls1 3rdgen swaps back in 2002.
BTW shameless plug.
Criticize this. (#3 swap for those keeping score.) Earlier in the morning this was nothing more then a roller after I had sold off the crossfire the week prior.
and it's a 98 with stock intake and heads. I'll still bet $10 it run's faster then that guys money pit TPI.
Total cost so far $0
BTW shameless plug.
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
LSx FTMFW, I have been bitten by this bug and now I want to convert my 79 malibu to an LSx, I love the new technology and I'm never going back to anything else other then LSx. The only regret of my swap... was not doing it sooner!
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Just food for thought. My 355 AFR headed TPI with 150 shot ran 10's.
, now I have an even badder TPI, any LS1's wanna run?
BUT, seriously, I have a 87 Iroc and a 99 SS(with a 408 that makes GREAT power), but the older I get and the less and less thirdgens that are around I don't think I could do a LS1 in a thirdgen although I see how and why people do.
BTW, when did the socal thirdgen scene become so popular? I haven't been on thirdgen in a while, but am very glad to see these cars redone in a different way than the 10 years ago. Young blood will keep these cars alive!
, now I have an even badder TPI, any LS1's wanna run?BUT, seriously, I have a 87 Iroc and a 99 SS(with a 408 that makes GREAT power), but the older I get and the less and less thirdgens that are around I don't think I could do a LS1 in a thirdgen although I see how and why people do.
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
One last time. I will try to make this as clear as possible. I never ever commented one way or the other on whether or not someone should put an LSx motor in their 3rd Gen car or the viability of doing so. That is their business. The reason I am posting in this thread was the accusations made by the original poster in post #1 about members of our club.
Now if the man from Austin cannot understand that statement so be it. If he has evidence otherwise point it out.
I can certainly see why some people may be angered enough to refer to the "club" as TPI-****-Purists. Is that clear?
You've made it evident several times, and I have spelled out my thoughts on the situation plain and simple, here in the LSX/LTX sub-forum.
Really I just continued to argue to bump the post so other members can see how this "TPI club" represents itself.
I agree with you though, as our cars get older and more collectible it would be hard for me to swap a LSX in one and ruin the original factory set up.
That's why I used my beat up old '89 Formy that needed a new block/trans anyway
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Like I've said, I don't think anyone here doubts the possibility of building a TPI to be fast. I've done it. But there are cam only cars with LSx motors running 10's, put a 150 shot on those (if you can get traction) you could see 9's. Add heads, well, you get what I'm saying.
Oh yeah, I agree. Our SS should run 10's NA FULL weight 6 speed.
and woulda run all over the Iroc on the street Member
Car: 1985 iroc z
Engine: 350 .30 over
Transmission: t-5
Axle/Gears: told aftermarket moser 3.73 posi?
The Lsx is the better motor does that mean everyone needs one no. But imho the lsx is better in every way am I a tpi basher or an lsx freak hell no I own a 305 tpi a carbed 350 and I have the 6.0 in my 03 sierra. My truck was cammed and geared and it beat on my 305 all day I know apples to oranges but I'm talking a big crew cab truck lifted 8 inches with swampers and just about every accesory imaginable... one more reason I say the lsx is better is the fact that my friend has a cammed ls in his 3rd gen he paid I think around 2500 for the swap and all parts he got the motor and 6 speed really cheap now I have a 350 cammed heads intake carb fuel pump all types of non sense and I can't beat him over all I spent more than him an have a slower car not t mention I get maybe 10 15 miles to the gallon tops he gets mid to high 20
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
I think I'm going to start a TBI club here in SoCal so we can admire those bulging two injectors out of the pseudo carb and glistening black air cleaners, only differing in the amount oil and gunk build up on them. Let us not forget about those magnifisant, trend setting elbows that flow like kazoos and allow for all 170 ponnies to be unleashed on the masses. Who's in?
I have a Q-jet on my 1983 van, it has lots of gunk and varnish from the old gas and the oil leak the previous owner didn't fix. Can I join!?
I did put nice new gaskets on it, but then a exhaust manifold cracked, so I put LT heddman headers and thrush glasspacks on it...I swear I've never seen so many bolts twist in half like old chewing gum before!
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
and by the looks of the thread the only benefit a TPI build offers over an LSX build is nostalgia.
I'm in no way a "TPI basher" as my posts have stated that I am impressed with the way So Cal has stretched the potential of the TPI but at the same time I'm rational and inclined to technology therefore upgraded to the LSX platform.
It has become humorous for myself and TPITERR to defend the LSX swaps against the TPI Cult/purist. Instead of the TPI Cult praising the blood sweat and tears that we have put into our cars we get negative feedback such as 1. "the LSX looks ugly" 2. "my TPI will spank you" (which I find comedic) 3. that a TPI could have been built for less $$$(which isn't anyone's business) etc.
Instead of encouraging expansion of 3rd gens enthusiast through younger generations with new ideas(LSX), the cult is becoming obsolete
Car: 1989 GTA
Engine: 369 TPI
"All I did was take the general consensus of the TPI Cult and burst its little bubble by exposing them to the rest of the world."
So how many members did you poll? I don't recall you asking for my opinion as an example. I think you are injecting your own thoughts and prejudices into your unfounded conclusions.
I suggest you go pick up any current recent issue of a GM oriented magazine...
Maybe take a look at Hawk's? But then again, they are just begging for business right?
Edit: Fear not, I've gone out into the world for you: http://www.gmhightechperformance.com...ula/index.html
One of my favorite swaps to date. Can't beat a blown LSx in a 3rd gen, best of both worlds for sure.
Note: That is a sleeper
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I don't understand your comment.
LS1 run 10's NA? yes.....
TPI thirdgen run 10's NA(yes, but it would be VERY hard)
OMG, bench racer FTL. I was joking around.
I have an LS1 too! Member
I'd be down, but I want to get ONE epic pass on film when I finish my head swap. If everything goes according to plan, I should SHOWER the track with piece of 10 bolt!
With slicks I have my fingers crossed for 10's, as long as the diff holds together
84 Z28...
none =D
oh okay, with the 'doh' i wasn't sure if you were being sarcastic or not
none =D
There are tons of fast TPI cars on here. None of them are by his hand
I cant believe how many TPI guys are comparing a heads/cam/nitrous TPI car vs a stock LS1. Duh, add the same stuff to the LS1 and youll have a VERY potent car thatll smash the TPI. Its more in line with the 305 vs 350 wars
305<350<LSx any way you slice it HP/$
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
On the tpi vs. lsx subject. All good things must come to an end. In this case it was the tpi engine. And personal preferance id like to see ANY stock tpi vs. a stock ls1.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Made my own section on LS1tech just for carbed LS guys, just because we are using the old tech and new engines, so many do not like it, but they can keep looking at tail lights.
As for TPI...thing of the past.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
dads LS1 ran 11.2 with heads cam and a few bolt ons (and straight headers)
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Car: 1986 camaro
Engine: ls2
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Really it is 6 of one half a dozen of the other. It does not matter what iron is under the hood if it was properly modeled and built to meet its requirements plain and simple. You wanna get out of the dark ages go get EAP. Type in your requirements how much horse you want how much torque you want, what platform you are going to build on (4th gen SBC or 1st gen SBC) see what it says. Then determine how much it will cost to get there with each platform. For some it makes sense to stay with a Gen1 SBC for others a complete pullout 3rd or 4th Gen SBC meets their needs.
Saying my car will beat your car is about as hill billy as it gets. There is always someone faster. Go watch Nelson TV on You tube. It is all a matter of engineering. He has twin turboed Gen1 SBC pumping out 1200hp. I imagine the car that goes into will scoot! On the same token I have seen a 427 Warhawk base LSx pumping out 800 hp NA.
It is personal preference and that is all it is.
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
if i had the money my Thirdgen would have an LSx in it, i would keep my little 305,rebuild it, and keep it in my garage until im ready to drop it back in WHEN these cars become desirable like 1st's(not going to argue that point, its how i see it)
but this is how i see the LSx nay Sayers, and no i have not read any a nay sayer has said, or do i even care because it honestly brakes down to the LS series being on top right now.
most of the time the 350 guys are throwing around that the 305 is a junk motor because it will only take you "so far" and a 350 is cheaper to build and will be faster, so when somebody challenges them and says then why wouldnt a 350 TPI guy go LSx(because i mean you can only go so far with a 350 tpi) and in the end an LSx is going to be cheaper and faster,
1. they don't like hearing that their motors are being considered "junk" like a 305(for the record i dont think any motor that came in these thirdgens where really "junk")
2. they may just be Purist's that believe whatever came stock should be what is in the car(even if the motor is no where near "stock")
its a never ending line of, well this motor will be cheaper and faster at the end of a build, and who knows what kind of motor will be out 10 years from now, but if i still have my RS and i have the money ill be damned if im not going to stick that motor in the RS
i was thinking the 305/350 thing the whole time!
Engine: L03, LB9
Engine: 5.7 350 TPI
and yeah im thinkin its not AS hard but its still quite a projectme to
funny how people will stand behind things when its someone elses stuff. i never asked for opinions, i asked for help/advice.
Car: 1990 RS
Engine: LO3 TPI
Transmission: W/C T5
Engine: L03, LB9
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Dont let this stuff get to any of you. i know when the LT1's came out there was alot of sh!!t-talk and its not even an engine used anymore. i had a carb b4 the swap didnt like it much and i witnessed all the crap the tpi guys i know go thru with that set up. personally i love My swap i will never go back to anything less. but if your stuck on tpi oh well good for you if it works for you then ok. its like i-pods vs cassette players. i know people who till have them lol not me
