LT1 383 into 82 Camaro
Car: 82 Camaro Z28
Engine: 305 Crossfire
Axle/Gears: 3:23
About to put my 383 LT1 into my 82 Camaro Z28. I have pretty much everything, however, the LT1 harness is not in the best shape. Is there someone I can have fix up the harness ? Also, is there a way to make the LT1 harness, 3rd gen compliant ?
Car: 1987 Trans Am
Engine: LQ9/L92
Re: LT1 383 into 82 Camaro
pocket's the man when it comes to wiring, but you're best bet would be to check out the lt1/ls1 swap subforum; everything you're looking for can be found in there
https://www.thirdgen.org/forums/ltx-lsx/
Car: 82 Camaro Z28
Axle/Gears: 3:23
Car: 1995 Camaro z28
Engine: 355 LTX
Axle/Gears: 4.10
If you dont want to do it yourself and have the money call these guys. They can do anything you want with your harness. http://www.lt1350.com/
Car: 92 Z28
Engine: Boosted LSX
pocket is a member here. look him up. and pm him.
more info on yor 383 lt1? pic's etc........ see sig. i have a 383lt1 also
Read this
https://www.thirdgen.org/forums/ltx-...rt-finish.html
Shoot me a PM if you're still stuck. You can simply repin the body connectors for a minimal effort conversion but make a mistake and youll pay hell tracking it down
1992 Trans Am
Aug 8, 2015 08:16 PM
