lt1 swap
Old Nov 26, 2010 | 07:22 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
Axle/Gears: Ford 9in w/ Strange 3.70s
lt1 swap
hey. i am currently trying to swap my 2.8l v6 for a 5.7l LT1 into my 1988 base camaro. my lt1 is out of a 1996 impala and ive already discovered the block motor mounts have to be shifted to get it to fit straight, now that its in the car, is there anything else i need to know? any and all replies are appreciated, this is going to be my first car and hopefully a future drag car so i would really like it to be nice and DONE RIGHT.
thanks,
chase
Old Nov 26, 2010 | 07:26 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
Re: lt1 swap
also, i would like to know if my block will handle a twin turbo kit, an estimated cost, and anything that will make my task a little simpler. if any of you have done this, can you give me an idea as to which type of turbo kit would be best; cost aside, i want this to be nice so ill pay whatever it takes
thanks
Old Nov 26, 2010 | 08:13 PM
Dr. Phil's Avatar
Car: 1987 Pontiac Firebird GTA
Engine: 383
Axle/Gears: 3.42 10 Bolt
Re: lt1 swap
I would do more research if I were you (on the turbos)
Old Nov 27, 2010 | 11:53 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: lt1 swap
you also have to move the frame mounts, I would suggest reading the stickies and doing a search in this sub forum
https://www.thirdgen.org/forums/ltx-lsx/
Old Nov 30, 2010 | 05:55 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
Re: lt1 swap
also, do you know anywhere i can find a new throttle body, like a 90mm, something thats a single port, not twins
Old Nov 30, 2010 | 07:35 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: lt1 swap
Wow. You don't seem to have a clear direction with what you are doing. You're asking the right questions but you need to do ALOT more research before commiting to a twin turbo setup. I would guess the engine, turbos, and custom piping are gonna run you at least $10K, assuming you do as much of the work as possible. Then you have to worry about the trans, driveshaft and rear end. If you are serious, you can find alot of info on this forum but get ready to open your wallet.
You can find a monoblade throttle body here http://www.tpis.com/parts/view/46
Old Nov 30, 2010 | 08:22 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
Re: lt1 swap
well thanks, ive already bought the engine with the transmission, and although its frowned upon, if already bought a ford 9 in rear with a strange positrac centersection with 3.70 gears. the engine is in and we are currently wiring it, but we have to install the radiator and condensor still, as soon as we get it to start it will be taken back out , a 4 in cowl is going on and its being painted black with satin black racing stripes. i was also wondering if you need a new radiator to work with the lt1 and what type and size fuel pump i need.
thanks
Old Nov 30, 2010 | 08:25 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
Re: lt1 swap
the fuel pump has to fit a 1988 camaro tank
Old Nov 30, 2010 | 09:42 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
Re: lt1 swap
i would also like to know what headers you put on yours or the best choice cause mine are completely rusted out
Old Dec 1, 2010 | 09:18 AM
1981LT1's Avatar
Engine: LT1; LT1
Re: lt1 swap
Any headers for the 3rd gen will work. Don't worry about the D-port heads. I am running Flowtech mid lenght headers but I wouldn't recommend them. They hit the passenger frame rail and the y-pipe is crap.
Old Dec 1, 2010 | 07:51 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
Re: lt1 swap
alright thanks, mines gonna have an offroad x pipe anyway, but ill probably end up getting flowmaster long tubes
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
