A/C K-member notch with motor in car?
Old Nov 17, 2010 | 01:33 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Anybody attempt it? I'm putting A/C back in the IROC this winter and really don't want to pull the motor to do it.
Old Nov 17, 2010 | 04:58 PM
$750 L98's Avatar
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
Re: A/C K-member notch with motor in car?
Good question, but I am pretty sure I'll have to pull my K-member for the pan replacement anyway...
Old Nov 17, 2010 | 05:34 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
thats how i did mine... in the car
Old Nov 17, 2010 | 06:42 PM
406TPI's Avatar
Car: 1985 IROC-Z
Good to know...I figured it was do-able but I thought I'd ask to see if anybody did it.
Old Nov 17, 2010 | 07:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
With the engine installed?
Having done two, with the K-member in the car but engine out, I can't imagine trying to do it with the engine in.
Now, one member did remove the K-member without removing the engine/trans (switching to tubular K-member, if memory serves), so you might want to consider that option. The engine was held up with a bar across the strut towers & chain.
Old Nov 17, 2010 | 07:36 PM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
I have removed the k-member with the engine still in place two times. Once back in the early '80 I did it using a bottle jack under the harmonic damper. Sort of scary setup but it enabled me to R&R the oil pan easily. Second time a few years back using an engine support bar across the strut towers.
Mike
Old Nov 17, 2010 | 07:44 PM
89' RS/blue's Avatar
Car: 1989 RS Camaro
I'm assuming your swapping in a LT1 like me....I have a 89 RS I'm swappin a 95' 9C1 cop car LT1 into....its has a oversized a/c compressor....and iits mounted bottom right on the system...which means w/out modification i'd have to notch the K member. However...**** that ****....I found that swapping to a lt1 vette' acc. mounting bracket relocates the a/c to the top right...solving all my problems. I'm just saying whatever setup you have....just seriously research it before you do uneccessary frame mods.....good luck man!
Old Nov 17, 2010 | 07:58 PM
five7kid's Avatar
Since his userinfo says:
Car: 1985 IROC-Z
I assume it is not an LT1.
Old Nov 17, 2010 | 09:21 PM
Engine: ls1, LB9
wasn't bad at all. I used a cut off wheel to make the cuts. clearly eng out would be simpler but i would do it again if the engine was in
Old Nov 17, 2010 | 11:52 PM
five7kid's Avatar
Wow.
Old Nov 18, 2010 | 04:55 AM
406TPI's Avatar
Car: 1985 IROC-Z
Negative. LS motor. And I'm not swapping it in, the motor has been in the car for 5 years.
Thanks everybody, I plan on doing it with the motor in and not dropping the K-member. I have a nice 90 degree cut-off wheel tool that I was planning on using, but I may snag a plasma cutter from a friend and use that if need be.
Old Dec 2, 2010 | 08:37 AM
406TPI's Avatar
Car: 1985 IROC-Z
Just as a follow-up. I did the notch with the motor installed...wasn't hard at all. I pulled the bolt out of the mount on that side and jacked the motor up about 2 inches so it rolled up and over. I used a 90 degree cut-off tool. Took about 20 mins to cut it out.
Old Dec 2, 2010 | 08:54 AM
Stephen's Avatar
Car: 87 GTA
Did you flip the cut out piece over & use it to weld the cut out closed? Or did you fab up a new filler piece?
Old Dec 2, 2010 | 10:29 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Yeah I read a bunch about cutting it...but what about welding it back up? Ya'll did weld it back up right? haha.
I vote drop the k-member. Invest in one of these...Comes in handy plenty.
While the k-member is down, and your cutter/welder is warm, notch for the oil pan. You might not need the notch...but you might. And it'll save you a ton of time if you just do it all at once and get the k-member sealed back up and painted.
Just my opinion...can def see being able to do it in the car. At least the cutting out part.
J.
Old Dec 2, 2010 | 11:32 AM
406TPI's Avatar
Car: 1985 IROC-Z
No, I didn't flip the part I cut out over and reuse it...I thought about it, and actually fitted it into the spot and was suprised how close it was to filling the hole. I wanted to add some extra bracing down into the k-member so I made my own pieces.
Lol..welding is the easy part.
Old Dec 2, 2010 | 12:32 PM
Car: 86 Trans AM
I cant say I 100% remember how much room there was come to think about it. I never had the motor in place without the compressor pre-notch cutting. I suppose with the compressor out of the way, and even the bracket, you'd have a good bit of room.
Ide still rather do it with the kmember out but I hate doing things, especially welding, in tight spaces. And like I said, if I ever do another swap, ill be notching for the oil pan right off the bat. In fact...Ide probably ditch the A/C and just notch for the pan. haha.
Either way that gets the job done works!
J.
Old Dec 2, 2010 | 12:34 PM
$750 L98's Avatar
I 'spose I'll remove my K member and do it, It would be nice to have some one reweld it with skill, unless a little flux welder can do the job. I might go ahead and have mine powder coated as well. Must have AC lol
Old Dec 2, 2010 | 01:30 PM
406TPI's Avatar
Car: 1985 IROC-Z
J.
Oh, no doubt...I would prefer to do it without the engine installed too! However....I really didn't want to remove the engine this winter just to cut the notch in. That's alot of work for about 1 hour of cutting and welding..lol. I just wanted to post up my experiances in case anybody ever wondered how easy it was with the motor in.
Old Dec 2, 2010 | 05:58 PM
five7kid's Avatar
No cutting/welding required:
http://cgi.ebay.com/ebaymotors/Camar...item4cf36b0a6f
You will have to buy a new compressor.
Old Dec 2, 2010 | 07:23 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Two members. Ghetto and I both That bar across the top is a miracle worker.
Old Dec 2, 2010 | 07:28 PM
$750 L98's Avatar
Certainly can't count on ARD to do it lol! I will probably try the bar idea or go with the PA racing K member. I'm just afraid the pan will be too exposed with a tubular K member, I already cracked 1 pan, a second would be brutal.
BlueIroc-Z
Jun 9, 2019 03:22 AM
colton_carlson
Mar 8, 2019 12:21 PM
1nastygta
Aug 8, 2015 07:38 PM
NBrehm
Aug 5, 2015 07:57 PM
