Gonna drop in the lt1 soon. So where do i hook up the chains?
Old Nov 28, 2010 | 02:43 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
so where do you guys hook up the chains to the lt1? I saw some use the front bolts and a intake bolt.
Old Nov 28, 2010 | 11:19 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Gonna drop in the lt1 soon. So where do i hook up the chains?
What state of assembly is the engine in when it will be dropped in?
I'd be wary of using the intake bolts on an LT1... IIRC, the bolts are quite small, and if they are aluminum heads, may not handle the load. The accessory bolt holes on the ends of the heads would probably be a better choice. Exhaust manifold bolt holes could also be an option.
Old Dec 3, 2010 | 07:22 AM
Carlos773's Avatar
Yea I figured exhaust manifold holes will do. What would be the siZE for the bolts? ' have beeen tod they are 3\8 16
Old Dec 8, 2010 | 06:40 AM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I used the holes in the front and back of the heads with grade 8 bolts. works perfect with no problems. motor was complete with intake on it as well but no accessories of course.
one bolt on each side of each head does it.
Old Dec 8, 2010 | 06:51 AM
Carlos773's Avatar
I hooked up via exhaust manifold holes with grade 8 bolts worked fine andfit like a glove.
GTAman
Jul 3, 2024 07:29 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
