86 z28 lq4 or ls2
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
86 z28 lq4 or ls2
I'm looking at doing this swap and ending with around 420 rwhp. would it be best to get an gto ls2/6speed or get and lq4/6speed and build the lq4
need the help
need the help
Transmission: 4L80E/4L80E
Take your pick. Less trouble with the GTO accessories, you'll already have a passenger car intake, LS2 weighs less, T56 can be gotten with the engine.
Both will need the oil pan changed. The LQ4 will cost a lot less to buy, but you'll have to find a T56, intake, accessories, etc.
I'm not sure of a verified number, put people are spraying or charging them to over 600 HP.
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: 86 z28 lq4 or ls2
performancewise it'd be pretty easy to hit 420rwhp with either engine
Engine: Cammed 6.0L LSX
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Car: 1989 Camaro RS
Engine: LH6
thats not too crazy, i hear about sales from 500-a little over 1000, look on ls1tech too, i'm sure you'll find a deal
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I paid 1200 for my LQ4. Complete engine , harness ecm and everything. 64K on it. Sold alot of it off. When I came down to it , all I reused was the shortblock. I threw on 243 heads, ls6 intake, new lifter, lifter guides, new pushrods and so forth. I used a Vette serp setup.
In hind-sight, it was not a good deal AT ALL... but not by fault of the price, it's because the block was junk and needed a complete rebuild. I'd pay $950 for another one with the harness and ECM again if I knew it was a good block. What I bought should have only been $300...but I didn't know until I pulled it apart.
Car: 1986 Firebird
Engine: 6.0L LSX
I picked my complete LQ4 w/ harness and accessories (minus ECM) up the other day for $450. It just hit 100K miles.
Not to hijack the thread, but any cam/spring recommendations if a guy is to swap the cam anyway?
look at texas speed, thats a sponser that a lot of the LSx guys use
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
i paid 1200 for my ls2 shortblock. for the money id go lq4 or 9 if ur not worried about weight. i like the 88lbs saved. Bluezee28's 6.0 build would be what i would copy if u want to go fast.
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
blackz281le
Jan 11, 2016 07:51 AM
86White_T/A305
Sep 21, 2015 05:28 PM
