I figure its been asked but i cant find it, 4th gen lts in a 3rd gen?
Old Dec 4, 2010 | 11:41 PM
otecnick88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350 .060 over carbed
Transmission: TH-700R4 w/2800 stall
Axle/Gears: 9 bolt w/3.27s till it breaks
like i said im sure its been asked a million times but i cant seem to find it, so will 4th gen lts fit a 3rd gen? im sure we have the normal concerns but where are the contact points? are they cross member issues? steering shaft issues? firewall issues? any thing like that
only reason i ask is becasue i have a tublar kmember about to go in the car as the ls swap starts, i was gonna use stock manifolds but my buddy is giving me a set of lts off his old 01 ss, of course i would rather use the lts
any help would be great, thanks fellas
Old Dec 5, 2010 | 12:04 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: I figure its been asked but i cant find it, 4th gen lts in a 3rd gen?
IIRC the 4th gen LTs won't fit, I think because of the tubes hitting the firewall, but somebody with more knowledge should jump in. Hawks makes LTs for LS1 swapped thirdgens, but they'll cost you a pretty penny.
Old Dec 5, 2010 | 09:01 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Ah...LongTubes. I was sitting here trying to think what motor an lts was haha. LTs from a 4th gen will not work at all.
On a 4th gen, they flare out to the sides, and would run right into the front subframes. Its not even close really. You'd have to hack them apart and rebuild them, and its just not worth it. At point you'd be way ahead just buying a header kit and going at it.
Go with Hawks or stock manifolds if you just want to buy, install, and enjoy.
J.
Old Dec 5, 2010 | 04:19 PM
haha yea i ment long tubes, see thats what i was tring to figure out, i have thrid gen lts but dont have fourth gens to compare too
who makes the build your own kit for the ls engine?
Old Dec 5, 2010 | 05:01 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
not too sure on the whole kit. but I know summit used to sell header pipe kits and then you buy the flanges for your setup (sbf,bbf,sbc,bbc, ls1 and so on)
Old Dec 6, 2010 | 07:46 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
people have modified 3rd gen sbc long tubes to work on the lsx motors, but the 4th gen stuff's a no go (other than shorties)
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
