carbed 4.8/5.3
Old Dec 17, 2010 | 01:05 PM
bigal's1991's Avatar
Car: 1991 camaro RS
Engine: currently swapping 5.3
Transmission: 4l60e
Axle/Gears: soon to be 4:11
carbed 4.8/5.3
Does anyone have any pictures of a carbed 4.8 or 5.3? I'm planin on swapin a 4.8 with ls1 stock manifolds and the msd kit to fire the coils, and 600 eldebrock. I'm goin to rebuild the 700r4 myself too. I have found a used 4.8 with 30,000 miles. I will be swapping the cam to a more aggressive one, 490 lift 278 diration. Please dnt give me the leave it fuel in jected crap, I'm not messing with that much wiring haha lol
Old Dec 17, 2010 | 02:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It'll look the same as a carb'd LS1, except for the cast iron block.
I don't think you're going to avoid any mess with a carb.
Old Dec 17, 2010 | 03:21 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: carbed 4.8/5.3
Just looks like whatever intake and carb you go with, most dont mount the MSD box where i do, otherwise, i understand the not going EFI, more peak power for less money:
Old Dec 17, 2010 | 09:06 PM
Car: 1991 camaro RS
Transmission: 4l60e
Re: carbed 4.8/5.3
I just don't want to mess with all the wiring and tuning, this is on a very tight budget 2500 motor, cam, fuelk pump, oil pan everything. I'm a lot more comfortable with a carb. its gonna be a daily driver and I'm 19, i
Old Dec 18, 2010 | 03:55 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: carbed 4.8/5.3
2500 for the budget? You have it covered, no problem if you know where to find the parts.
Old Dec 18, 2010 | 03:56 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: carbed 4.8/5.3
Also, here is the carbed section i had opened up on Tech for us guys that avoid the EFI:
http://www.ls1tech.com/forums/carbureted-lsx-forum-172/
Old Dec 18, 2010 | 08:45 AM
Car: 1991 camaro RS
Transmission: 4l60e
Re: carbed 4.8/5.3
I have found a couple 4.8's for 600 but I an willing to pay for low miles and on that I
Can hear run. I jus think a carbed 4.8 would be something different for my car, imy 91
Is hugger orange, with whitw stripes, 4 inch cowl hood, and 18 inch iroc reps. Lol it should
Be a great motor and get decent gas mileage.this is my daily driver
Old Dec 18, 2010 | 10:04 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: carbed 4.8/5.3
I'd toss in a 5.3L for a couple hundred more if that. I've bought probably a dozen 5.3L in the chicago area for 350-550 from ebay, ls1tech and junkyards. These are 50k-90k motors.
Old Dec 18, 2010 | 03:31 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Re: carbed 4.8/5.3
https://www.thirdgen.org/forums/engi...t-lq9-58k.html buy this bro its a steal
Old Dec 18, 2010 | 06:53 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: carbed 4.8/5.3
I could probably get you a 5.3 shipped to your door for 600 or so, long block.
Old Dec 19, 2010 | 12:52 PM
Car: 1991 camaro RS
Transmission: 4l60e
Re: carbed 4.8/5.3
Really? I want a really low mile motor, ilve found some that are around 90000 miles but I'm lookin for a 30,000 mile motor, I'm gonna swap the cam and put on ls1 manifolds and the msd carb kit and intake....and I'm gonna use my 700r4, would u need a different trans mount??
Old Dec 19, 2010 | 05:11 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: carbed 4.8/5.3
Never used a stock trans crossmember with a LS swap yet, but the 700R4 can work very well if you can get the lock up to work if indeed it is a lock up model.
Mileage would vary, would be around 100K, some times less, but i have a 177K mile 6.0 in my 2001 3/4 ton that put down 292 RWHP and 312 TQ on a dyno tune a couple weeks ago, so mileage doesnt hurt that much, my 89 RS 6.0 has a bit over 100K miles on it when i swapped it in with a cam.
Old Dec 19, 2010 | 06:35 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: carbed 4.8/5.3
skip the 700r4 and toss on a 4L60e and let the computer control it like it's supposed to would be the best bet. No reason the stock crossmember won't work, but if you want that torque arm off the trans then I'd buy an aftermarket setup.
Old Dec 19, 2010 | 08:22 PM
Car: 1991 camaro RS
Transmission: 4l60e
Re: carbed 4.8/5.3
I'm carbing the car, so no computer, and I would rather have a 5 or 6 speed, aren't earlier 700r4s are non-computer comtrolled??? if I can afford it then ill be swaping in a t5 with the motor.
Old Dec 19, 2010 | 09:07 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: carbed 4.8/5.3
700r4 wont last behind that motor. Buy a t56 for a gen3/4 motor or you're looking into built autos like a th350/400
Old Dec 21, 2010 | 07:15 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: carbed 4.8/5.3
Yea, if you did make the T5 work, it would be on borrowed time as well as the 700R, the 700R can work if you build it, but for any real power, they are just going to last to long before something gives, anything i can afford that is.
Old Dec 22, 2010 | 03:08 PM
five7kid's Avatar
Re: carbed 4.8/5.3
With a 4.8 or 5.3, we aren't talking about more power than a T5 or TH700R-4 can take.
With the longevity these engines exhibit, it doesn't make sense to pay a premium for a 30k engine. I've got a 147k 6.0, that was clearly not well-maintained, that still shows cylinder wall cross-hatch. My son picked up a 5.3 with 120k miles for $300 that he's going to put in his '96 S10 (his has to be an emissions-legal swap, so he needs to stick with EFI).
I still say it's wrong-headed to think a carb'd swap will be less hassle or cost less than an EFI set-up, but as always, you can lead a horse to water, but you can't make it drink.
Old Dec 22, 2010 | 04:52 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: carbed 4.8/5.3
If he is carbed already, then it is simply 600$ or so.....and WAY less headache for someone that knows nothing about wiring.
I have seen the T5 break behind stock 305s and i have seen them last behind my 500 HP 383s so it is just hit and miss.
The 700R can work, but for how long? Might be a long time, might not be, the 700R is just not that great of a trans with my experience, not till i have it rebuilt.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
