Help me identify these connectors
Old Dec 24, 2010 | 07:53 PM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
I did a search but couldn't find what I was looking for. My harness must have gotten pinched during pullout and a few wires got snapped and I have no clue where they end or what they are for. This is an 06 blue/green truck harness btw
What are these?
This one is for the alternator, but the blue wire was cut...where does it lead?
Old Dec 24, 2010 | 10:15 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Help me identify these connectors
Left, trans shifter connector for trucks, delete
Middle, AC compressor clutch, optional
Right, oil level sensor, delete
3rd alt wire is the phase sensing wire IIRC. Ill look it up later
http://www.ls1tech.com/forums/conver...lternator.html
Old Dec 24, 2010 | 11:12 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
pocket, do you have a link to all the connectors up close like that and what their functions are? I was going to add to my cable harness thread a few that I'm unsure of as well. A thread with each one including wires and a connector pic up close and it's function would be really helpful.
Old Dec 25, 2010 | 09:29 AM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
I went through the truck pinout diagram and the only DK BLUE pin that is not accounted for is pin 73 on the green connector(Fuel Level Sensor Signal -Secondary) which is not needed, but it doesn't make sense that it would be tied to the alternator?
*Edit
Found the answer:
http://www.ls1tech.com/forums/attach...-connector.gif
My next question...If I use an LS1 alternator can I just eliminate everything but pin B from my truck harness?
Old Dec 26, 2010 | 02:13 PM
Pocket's Avatar
Car: 91 Trans Am
Yes you can
xpndble:
https://www.thirdgen.org/forums/ltx-...erchanges.html
Old Dec 26, 2010 | 11:36 PM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
Cool. Thanks for the help.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
