plug and play swap harness?
Old Dec 30, 2010 | 12:30 AM
bigal's1991's Avatar
Car: 1991 camaro RS
Engine: currently swapping 5.3
Transmission: 4l60e
Axle/Gears: soon to be 4:11
ive seen the plug and play harness' for sale for around 1,000. are they truly plug and play? im jus wondoring bc i will most likly be swapin a carb(msd box to fire the coils) on my 5.3 because i dnt want to mess with all the wiring. i have alot of ?'s would i use my stock harness? would my dash gauges work? how hard is it to swap it all? sry i know i've been posting ALOT but i really want to do this swap. thanks for all the helps guys.
Old Dec 30, 2010 | 12:50 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: plug and play swap harness?
you don't need a harness if you go carb and the msd box, it will include the harness for you. You will be responsible for wiring gauges and your alternator yourself obviously. Read the sticky, and be prepared to spend at least 2500, if not more like 3000 when you're done.
Old Dec 30, 2010 | 10:02 AM
Car: 1991 camaro RS
Transmission: 4l60e
I already have 2001 z28 exhuast manifolds for it and the oil pan and pickup for 80 bucks. Yea I'm tryin to do it as cheap as possible with cutin corners... I'm gettin the kwik performance brackets for ac ps and alt, I'm gonna use the stock radiator and get dual fans, I'm rebuilding my 700r*, unless I can find a cheap 5 or 6 speed.
I was talkin about how easy the plug and play harness' were to leave it fuel injected. But I'm stickin to carbed.
Old Dec 30, 2010 | 08:34 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
if you're wanting to do it cheap stay FI and do the wiring yourself. It is around 8-12 wires that have to be spliced in for everything to work. Finding an LS1 intake is cheaper than buying a carb intake and carb.
Old Dec 30, 2010 | 08:56 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Not trying to tell you what to do but there is probably more money carbing it. The wiring looks tricky but if you read the stickys carefully and ask questions when you need to things are simpler than they appear.
If my car were running I would come down and help ya out :P.
Jorlain
Aug 24, 2022 05:11 PM
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
jharrison5
Aug 19, 2015 05:53 PM
