quick question on engine transportation
the end of this week im picking up an LT1 for my 92 firebird, and all i have to haul it in is a 94 explorer. i thought i could maybe lay the seat down, plump it in a tire, and strap it down back there? or will i have to find a friend to haul in truck....
anything answers/advice will be much appreciated. thanks
anything answers/advice will be much appreciated. thanks Joined: Aug 2006
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: quick question on engine transportation
a tire works, just be damn sure its strapped in really well. Not sure what the explores has for cargo anchors. You dont want to panic stop and have a 800lb hunk of iron come smashing into you
truck it the best bet.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Unless you make a basic cradle for it to sit in from a bunch of 2x4's, putting it in a tire is the simplest way. One 8' 2x4 is enough to make a cradle. Tie straps don't need to be extreme unless you drive like an idiot. You just need enough to keep the engine from rocking around.
NinjaNife
Aug 23, 2015 11:49 AM
