How did you move your car with no front suspension?
Old Jan 9, 2011 | 04:01 PM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Trying to take my car to the paint shop to get the engine bay done since everything (I mean everything) is out of the engine bay. How )if you did) did you move your car around? Any help would be great.
Old Jan 9, 2011 | 04:10 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: How did you move your car with no front suspension?
So the whole k member is out? Can you just bolt it back in and put the springs on? That's all you really need is the springs to keep the front off the ground.
Old Jan 9, 2011 | 04:25 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I have used an engine hoist to lift the front of a third gen onto a trailer before, but with everything out of the bay, I am not sure what you can attach it to.
Old Jan 9, 2011 | 05:11 PM
rdway's Avatar
Car: 82 firebird
Transmission: Automatic
How about a set of these with a 4 or 6 by 12 block of wood about 4 feet long and placed under the trans mounting area? You could drill holes in the dollies and run lag bolts into the wood. Just a tought, I have my front suspension out right now also.
http://www.jegs.com/i/JEGS/555/80070/10002/-1?CT=999
Old Jan 9, 2011 | 08:01 PM
Pocket's Avatar
Car: 91 Trans Am
Id put a K-member and A-arms back in at minimum. Springs would be nice but a block of wood will do in a pinch
Old Jan 9, 2011 | 10:58 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
I would use a large furniture dolley ($20-$30 at northern tool)
then use a piece of 4x4 post to bridge the gap where the k-member was.
You should be good to go at that point
Old Jan 11, 2011 | 10:10 AM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Go get some air filled dolly wheels and make a frame to bolt in there. Or I'm with them... Just install the k-member back in.
Old Jan 11, 2011 | 10:56 AM
topflyt's Avatar
hi im keith i have convertible camaro and wanted to put a ls1 with t56 in it were do i start far as mounts,cross member ,wiring, and ac
Old Jan 11, 2011 | 11:49 AM
Pocket's Avatar
Car: 91 Trans Am
Welcome to thirdgen.org
Please read the LS1 swap sticky at the top of the forum. It goes over the basics like you've listed
customblackbird
Aug 15, 2021 10:16 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
