i need help quick please
Old Jan 16, 2011 | 04:57 PM
8732's Avatar
My buddy sold me his 87 gta with a 5.3 ls engine in it. Theres not much left to do besides wiring valve springs and tranny bolted to engine.
Can someone please walk me through these last things.
How do. I bolt trans to engine its a 700r4 and how do i do valve springs
Old Jan 16, 2011 | 05:15 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: i need help quick please
i suppose the engine is in the car? if so you must want to change them. you can either make the tools or buy them to change the springs. what harness do you have on the car now. as for the tranny you will have to visit bowtieoverdrives and order the parts needed for the tb and tranny to work. and a custom tune. we really need more info.
Old Jan 16, 2011 | 05:23 PM
8732's Avatar
Yes engine is in car. I have all the parts to finish it from my friend i just need assistance on getting it done. The ecm is all ready tuned. What tools will i need for springs? The wiring harness is custom by the guy who bailed halfway through swap
Old Jan 16, 2011 | 05:47 PM
one92rs's Avatar
Car: SOLD!!!!!
a fitting to put air in the cylinders. then you can make a tool for the springs. do a search someone just made one while doing their swap. as for the harness part look thru this---
https://www.thirdgen.org/forums/ltx-...rt-finish.html
Old Jan 16, 2011 | 06:09 PM
8732's Avatar
Ok thanks. Now how bout that transmission. as far as bolting it to the block? Is there anything special i need
Old Jan 16, 2011 | 06:22 PM
one92rs's Avatar
Car: SOLD!!!!!
do a search (advanced) and punch in 700r4 in there. there is a lot of stuff to considder when doing a 700.
Old Jan 16, 2011 | 06:28 PM
8732's Avatar
Ok cool do you think a. T5 would hold up?
Old Jan 16, 2011 | 07:11 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
no way, you are better off with the 700r4. but the 700r4 is usually week unless it is very well built. make sure u have the proper spacer to connect the 700r4 to the ls engine. i bought a hughes spacer and it was like 50 bucks, but u said u have the engine already bolted to the trans so that might be a nightmare.
Old Jan 16, 2011 | 08:06 PM
Pocket's Avatar
Car: 91 Trans Am
A 700R4 or any other non-LSx trans wont last 5 minutes of run time behind a LSx engine without the crank adapter to hold the converter snout centered. If its bolted on there already, its got to come back off
Sounds like you bought a basket case. Id starter over and redo everything to make 100% sure its right. Doing things over is a pain as youll find with the trans
Old Jan 17, 2011 | 09:21 AM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
yeah, probably best to pull the drivetrain and do it right. chasing all the crap down that you can't see now thats wrong will probably make you hate the whole car.
Old Jan 17, 2011 | 10:01 AM
8732's Avatar
i only paid 1k for it. im taking it to my uncles garage and were ripping this thing all apart and doing it all the right way and were even going to rebuild the engine to make sure it will run to its best. the transmission is getting a reverse valve body and its getting pro street built. what the hell is the adapter everyone keeps talking about?!@?!?!!@#@!#$ send me a link to it so i know what to buy.
im thinking about just buying back the formula and dropping this thing in there and throwing a t56 behind it since the formula has a t5 in it all ready
Old Jan 17, 2011 | 10:03 AM
8732's Avatar
nooooo!! i said i need helping getting the transmission bolted to the engine. as of right now the engine is just bolted to the frame. the transmission is not connected yet
Old Jan 17, 2011 | 01:03 PM
Pocket's Avatar
Car: 91 Trans Am
3 options for the trans
1) Buy a LSx specific converter
2) GM 01+ 6.0 to 4L80E adapter w/ longer bolts using a flat flexplate
http://www.ls1tech.com/forums/texas-...manifolds.html
http://www.compnine.com/index.php?u=...00&grouptype=B
3) Hughes adapter with a dished 4L60E flexplate
http://cgi.ebay.com/ebaymotors/Hughe...item4cf403dac3
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
