89 TPI
89 TPI
HELP!!!!
I HAVE A 89 CAMARO 5.7L TPI WHICH I WANT TO REPLACE WITH A 94 LT1. I GOT EVERYTHING FOR THE LT1 ENGINE HARNESS TRANS. HOW TO I CONNECT THE 94 PCM TO MY CAR THE GUY THAT HAD THIS CAR CUT ALL THE WIRED AND TOOK OFF THE ECM. NEED HELP TO GET IT RUNNING
Transmission: 4L80E/4L80E
First, welcome aboard thirdgen.org.
Second, just so you know, I moved this to the "LTX and LSX" subforum of the engine swap forum.
Third, read the LT1 swap sticky in the top section of this forum.
And, just for the sake of civility, could you not type in all-caps? Makes it look like you're shouting at us...
Sanjay
Aug 12, 2015 03:41 PM
We've all been there
