truck front accessories with cowl hood?
Car: '89 Camaro
Engine: 4.8, ls9 cam, mpt76
Transmission: Built 4l60e, 3600 stall TC
Im doing a 4.8 swap into my 3rd gen and was wondering if i could get away with using stock truck accessories if i got a cowl hood. i guess im just not sure what exactly gets in the way... if anyone knows if cowl hood is an option let me know. thanks
Car: 1991 vert camaro
Re: truck front accessories with cowl hood?
Do some looking around on here, the alternator will probably hit the hood and the intake is pretty tall. Im using truck acc. but I modified the alt bracket and moved it to the pass side.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Hope to see how mine does with the truck bracket and original alternator.
Car: '89 Camaro
If the only thing is hood clearance, then wouldn't a cowlhood solve that problem? I guess that was my original question... And zones98rs, if you get yours in there before I do, lemme know how the fitment is.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
There is no doubt in my mind, the stock alternator can work with the F body or truck brackets, requires some imagination to do it a couple ways, but it nearly fits in perfect. But having a welder, chop saw, drill press and other tools make doing these things way easier, it is not a direct bolt in, but one way for the truck piece is to have a drill.
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Dialed_In
Aug 20, 2015 01:45 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
