LT1 power
Car: 1990 camaro rs
Engine: 305 tbi
LT1 power
Whats the best way to build power on a LT1? might be gettin a 95Z that got a cam, headers, built tranny and 4.10 gear....is a 383 kit worth it on a LT1 or is there a better way to make power?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: LT1 power
We will assume you are going to put this motor in your 3rd gen?
What are your power goals? A "383" kit is more than just that. It will require a complete rebuild of the current motor and doesn't include machine shop costs, gaskets, bolts, etc.
What are your power goals? A "383" kit is more than just that. It will require a complete rebuild of the current motor and doesn't include machine shop costs, gaskets, bolts, etc. Member
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Re: LT1 power
Lose the cam thats in it and call up loyd elliot or advanced inductions and get a head and cam package and forget the stroker. Get some good rod bolts and call it a day.
Car: 1990 camaro rs
Engine: 305 tbi
Re: LT1 power
well what can I expect to gain frome say the 383 kit, besides lots of torque which is what I'm shooting for. And I know I'd have to get it machined too.
And I'm not sure if it'll be switched over yet, its got a nice setup as is. might just fix it have some fun for a while, and sell it for a profit.
And 1badeagle what kind of power has been proven with the packages your mentioning?
Car: '90 RS
Engine: 377 LSX
Re: LT1 power
There is no set answer to this. Infinate possibilities. You could have a 383 LT1 make 150hp or 500hp based on the conbo of parts. Its better to work backwards for you plan. What type of power do you want? How "big" is your budget? Are you dead set on an LT1 for your power goals (see question 1)?
Car: 1990 camaro rs
Engine: 305 tbi
Re: LT1 power
I was hopin to spend around a grand or so and at least 300hp/tq to the wheels so thats like a lil over 400 to the crank right?
Engine: 370 LSX
Re: LT1 power
300whp is doable with bolt ons dude. My old lt1 350 made over 400whp with le2 head and cam package. I had tons of torque.
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: LT1 power
93z28 169k,4l60e,speed density.
Longtubes,true duals
Upgrade to 24lb from the 22s for 93
Pcm for less chip
Dynod 282hp and 313tq
now add new valve springs and 1.6 or 1.7 rockers you should meet that goal!
you can blow those #s completely out of the park by using a cam head package from
either Lloyd or AI then look toward to 360- 410
I have a bolt on 6spd car in sig that puts down 320/336
sailtexas186548
Aug 24, 2015 10:11 PM
