LT1 Mystery Wire
Old Feb 21, 2011 | 06:43 PM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
LT1 Mystery Wire
I'm in the process of setting up a wiring harness for an LT1 and I've come across a wire that I can't find info on. It's on a B-body wiring harness and it connects between PCM B18 and as far as I can tell C204 B3. The C204 has also been confusing because some wires seem to be in different spots that what I think they should be according to the diagrams I have. I've been using diagrams from lt1swap.com as a reference.
Any ideas?
Old Feb 22, 2011 | 11:49 AM
Firebat's Avatar
Re: LT1 Mystery Wire
Looking at the PCM pinouts on LT1 swap -
http://www.lt1swap.com/lt1_pcm_pinout.htm
Looks like B18 is a pnk/blk wire only on 94 b-body and isn't needed. Why it isn't and what it does, I don't know either. I'm guessing it's ok to not connect it to anything. You could email the owner of lt1swap.com and see if he has an explanation of the B18 wire.
Old Feb 22, 2011 | 04:55 PM
caffeine's Avatar
Engine: 3500T
Weird. I was assuming my motor was a 95 because it has a vented optispark...
Old Feb 24, 2011 | 02:59 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
All b-bodys got vented opti.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
