LSX swap for '91 v6 Firebird
Old Mar 23, 2011 | 12:29 PM
bigpeet's Avatar
Car: '91 v6 Firebird T-top
Engine: 3.1 - not for long
Hi!
I am starting a long process of restoring my '91 t-top Firebird. I have owned the car for about 13 years and about four years ago it stopped running. I didn't have time then to work on it much to find out what is wrong. I can't bear to part with the car, so I decided then to restore it. Since it won't run anyway, I've decided to do an engine swap. I've never attempted anything like it before, but always enjoy working on cars. I think I will likely go with an LSX, if I can find a decent one for not too much cash.
This car won't be used at the strip, or likely as a daily driver, either. I would like a decent amount of power (for fun and enjoyment, but also for a little bit of bragging rights), without losing the drivability of the car (not taking out the A/C, etc). I don't need to make 500 HP, or run in the 10's, or anything crazy like that. I just want the best balance I can get between drivability/gas mileage and power. I know some would say that's ridiculous (after all, who drives a v8 for the gas mileage), but I just want something that is fun to cruise around in, sounds great, and doesn't get like 8 MPG (and then I can't afford to drive it at $3.30+ per gallon).
Are there any tips on what can be done to achieve this with an LSX?
Thanks!
-bigpeet
Old Mar 23, 2011 | 03:41 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Re: LSX swap for '91 v6 Firebird
Get a nice used 5.3 or 6.0 truck engine and go from there. Just change the intake manifold to a ls6 version. It may seem Like a hard task but it's not.
Old Mar 23, 2011 | 07:44 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Great gas mileage and power is easily achievable with a 3rd gen LSx fbody. Start doing some research and digging through some of the builds here and you should be able to put together a good idea of what your getting yourself into.
Old Mar 23, 2011 | 09:16 PM
Pocket's Avatar
Car: 91 Trans Am
5.3 or 5.7 dropout fit your goals. I beat the tar out of my 5.3/4L60E swap and still got 27mpg highway pretty regularly. Would have been higher if I kept my foot out of it more. Even a stock swap was over double the power of the old 305
Old Mar 24, 2011 | 09:12 AM
bigpeet's Avatar
I have seen a ton of nice builds on here! I'm hoping one day my car can turn out even half as nice as some that I have seen. I'll keep browsing the site.
Since I'm going to be building a little at a time (time and money permitting), is it wiser to buy the engine first, or the components to make the car ready for the engine (K-member, suspension components, etc.)? As I said, I'm new at the restoration game.
Old Mar 24, 2011 | 11:42 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if the car's driveable (which it sounds like its not), i would have started with all the suspension and chassis stuff - you can still drive the car while upgrading those parts. collecting the engine & swap parts takes a while and a good chunk of money, don't need more downtime than necessary if its gets driven a lot.
if you can find a complete ls1 setup out of an fbody, it will cut down on some of the extras you need to hunt down when you buy a truck motor (accessories, intake, pan, etc). may cost a bit more up front, but it'll save time and money down the road.
5.3L is a nice option if you can get the fbody stuff for a reasonable price.
(i do realize i've ignored all of these recommendations myself, but i like the hard way sometimes and don't mind waiting around for deals to pop up)
Zane Story
Oct 8, 2015 12:40 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
usafirebird
Sep 29, 2015 11:58 PM
89bird2.8
Sep 18, 2015 07:46 PM
