ls1 swap ?
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
ls1 swap ?
ok so when swaping to the ls1 from a lo3 do i need anything like somthing to make the speedomiter work or will everything work by just doing the wiring harness?
Transmission: 4L80E/4L80E
You need to wire the LS1 VSS output to the speedometer input.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
