Clutch Question: LSx & T-56 into 1985 Z28
Old Apr 16, 2011 | 10:11 PM
Joes1wood's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 Liter
Axle/Gears: 10 bolt 3.55 POSI
I'm thinking about putting an LSx and T56 into my Z28. I already did a 350 with the "retrofit" T56, so I used the stock clutch.
How should I go about this next swap? Is it possible to use my "retrofit" T56 w/ the T5 Bellhousing?
Is the LSx clutch different than SBC?
I've been looking for information on this, but everything is very contradictory from website to website.
Old Apr 17, 2011 | 12:03 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: Clutch Question: LSx & T-56 into 1985 Z28
Im sure someone else will chime in with a hard yes or no to this but Im fairly sure that the retro t56 stuff is not compatible with the lsx.I believe bellhousing,cluth type being pull vs push hydraulics,and input shafts are all different and would need to be converted.
Old Apr 17, 2011 | 12:57 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I dont think it will work. I think your going to need an LS input shaft, clutch, and the LS bellhousing. The LS motors use a hydraulic throwout bearing instead of a clutch fork.
Old Apr 17, 2011 | 02:32 AM
sargenewk17's Avatar
Car: 92 Camaro RS
Engine: LS2
Axle/Gears: 12-Bolt with 3.73
Bellhousing and input shaft length are different. For the hassle to convert it you might as well sell the one you have and buy an LSx type T56 (that's what I did).
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
greenyone
Sep 2, 2015 03:39 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
