using a gto t56 in a f body
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
I have just picked up a t56 setup from a 2004 gto. i have read about changing the shifter cup in the t56. is this just the tail housing or is there more? also if anyone has a website for the parts.
I have one more question. i have seen alot of debate about which pedals to use the 3rd gen or ls1 is one easier or better? thanks
Car: 91 Firebird
Engine: 6.0
Re: using a gto t56 in a f body
a quick search on LS1tech netted me this result
http://www.ls1tech.com/forums/manual...-firebird.html
I looked into doing the swap when I broke my T56, but decided just to rebuild what I had
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
I am running the MN12 in my car, you don't have to do anything to the tailshaft or the housing. Just change the shifter cup, buy an f-body shifter, and you're good to go! Oh and you have to use an LS2 starter with the MN12 bellhousing, I've tried using the f-body and truck starter and neither one fits.
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Engine: LSx 5.3
Car: 1984 T/A
Engine: LQ4
Car: 1988 Irocz
Engine: 350 sbc
Axle/Gears: 3.42s i think??? never checked
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I am pretty certain the GTO T56 uses the same tailhousing as the F-body. So your mounts are the same. However, there are plenty of aftermarket cross members that can relocate it.
ambainb
Apr 25, 2016 09:21 PM
TheTraut88
Sep 7, 2015 05:22 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
