new injectors = lean condition?
Subscribe
Apr 22, 2011 | 01:49 PM
So if everything else stays the same, that is, fuel pressure and pulse width, would a simple upgrade to bigger injectors cause my O2 values to be screwy? I had a set of old 30lb Accel injectors and I figure I'd put them on the car since it sat for a while and my blm's are sitting at 160 instead of 128.
Reply 0
Apr 22, 2011 | 09:05 PM
Re: new injectors = lean condition?
Is the tune set up to run the 30lb injectors?
Reply 0
Apr 22, 2011 | 09:31 PM
Nope. Its set for stock injectors. I will get it tuned but I wanted to know if this us te reason or if something else is wrong.
Reply 0
Apr 22, 2011 | 09:39 PM
well if your truly going from 24 to a 30 # injector and no tune was changed then you should be rich like you thought. check fuel pressure and maf
Reply 0
Apr 22, 2011 | 09:46 PM
Fuel pressure is stock for now and I just replace the maf due to another issue. I'll get it tuned as soon as it's roadable.
Reply 0
Apr 23, 2011 | 09:32 AM
Quote: Fuel pressure is stock for now and I just replace the maf due to another issue. I'll get it tuned as soon as it's roadable.
so you checked these ? or you guessing nothing is wrong
Reply 0
Apr 23, 2011 | 12:56 PM
Yes I checked them.
Reply 0
Apr 25, 2011 | 07:40 PM
Likely one or more of the injectors is stuck closed from sitting on the shelf. Send them off for cleaning and flow testing.
Reply 0
Subscribe
