some useful part numbers for the little things
Old Apr 28, 2011 | 03:39 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Hey guys,
I know I spent quite some time looking for these for my own purposes, thought maybe my effort could go to some better use for you other swappers in need of the little things
12557752 oil pump seal (always replace when you change pick up tubes)
12570326 GM Cylinder Head Dowel (missing on my shortblock)
12498545 97-03 head bolt set (per head) GM normally sells per bolt
17800568 04+ head bolt set (per head)
12602548 Coolant crossover pipe LS3
12605716 Coolant crossover pipe L92 - using this on the rear of mine
12602540 Coolant Caps (need 2 if your going to block off the rear)
12551933 Coolant Seals, Head (each) - use for sealing crossover pipes
12577927 newest LS6 valley cover (with bolts and gasket included)
12594779 pcv (or lack there of) hose for LS6 valley cover conversion
12610046 6.0/6.2 head gasket (each) - low cost, high quality MLS
hope this makes searching a little easier for some of ya!
Old Apr 28, 2011 | 04:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Copied the info to the swap sticky.
Thanks for posting.
Old Apr 28, 2011 | 05:37 PM
Iroc'nthe87's Avatar
Re: some useful part numbers for the little things
I'll add some:
Bolts through clamshells GM PN:11516940 and the accompanying Hex-Nuts GM PN: 11515744
Old Apr 28, 2011 | 07:02 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
anyone have ls1 car intake bolt p/n?
Old Apr 28, 2011 | 07:16 PM
Quick google search says "12552344." You can always call up your local dealer and confirm part numbers.
Old Apr 28, 2011 | 07:20 PM
mw66nova's Avatar
Engine: 7.0L
thanks! i should have thought of that though, lol
does anyone have just ONE bolt layin' around by chance? lol
Old Apr 28, 2011 | 07:45 PM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
The cost of the 17800568 set saves a bunch of money over 10 and 5 per head of the two individual part numbers. Wished I'd have had the number sooner.
Mike
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
twest2k2
Aug 24, 2015 11:26 AM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
