89 camaro w/ 99 z28 ls1 w/T-56 vid
Car: '89 Camaro RS
Engine: 5.7 LS1
Transmission: 6 SPD.
Axle/Gears: 3.25
didn't know exactly where to put this, since its part of a swap, had the time to make a clip for youtube. enjoy!
http://youtu.be/WzWaOEP8aFE
Transmission: 4L80E/4L80E
LSx subforum works...
Sounds good. Nice instrument cluster.
You might want to look into extending the air inlet into the corner of the engine compartment to get it away from the radiator heat, and getting a bigger air filter.
Car: 89 Camaro-RS
Engine: 305ci
Axle/Gears: 10 bolt posi
Re: 89 camaro w/ 99 z28 ls1 w/T-56 vid
Nice gauges, Nice swap.
Was it easy to get your gauges to work?(Especially the speedo and tech)
Car: '89 Camaro RS
Engine: 5.7 LS1
Axle/Gears: 3.25
57kid- thanks man! i thought of doing that once i get the battery relocated to the trunk so i can move it out the fans..
Raider RS- actually it was pretty simple, all the gauges work with a brain you have to buy seperately but speedo, tach volts and everything goes like any other signal, then it hooks up to the brain and transforms whatever signal readable to the proper gauges. the cool thing with those is that it has a feature were it flashes the gauge u program to "warn" and "peak" . like i have the tach blink like a tach light and is noticeable. theres alot you can do with these gauges..
