Racetronix Walbro 255 questions
Old May 5, 2011 | 09:42 AM
ssantac's Avatar
Car: 83 Trans Am
Engine: Soon to be 6.0l LQ9
Transmission: Soon to be 4L60E
Hi everyone,
I was wondering if this is the pump everyone is running.
http://www.racetronix.com/RX-FL98-FPKG-2.html
Also if any of you have bought the upgrades like the 'hot wire uprgrade', battery ground, or the pump booster interface connector kit? Are any of these necessary, or just a nice to have kinda thing?
Just trying to get a feel for what all I need to do the fuel pump side.
Old May 5, 2011 | 09:58 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
This is what I used for the LS1/4L60E swap:
http://www.summitracing.com/parts/VPN-GCA758-2/
Old May 5, 2011 | 03:11 PM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Re: Racetronix Walbro 255 questions
I am using a TRE 255 fuel pump for my LT1 swap. I am also running a high amp relay with 14 gauge wire from the battery to the relay and 10 gauge wire from the relay to the fuel pump. I found the my factory ckt had 1.5 ohms of resistance in it.
I would have ran 10 gauge throughout, but I discovered the high resistance in the body harness after I built my engine harness. Then I went and got the heavy gauge wire. Like it is I should be able to support two 255 pumps if I needed to.
Old May 5, 2011 | 07:21 PM
ssantac's Avatar
Car: 83 Trans Am
This may be a dumb question, but I didnt see it noted. Does this come with everything pictured? Also the racetronix is only 20 cheaper with the hotwire upgrade. Did you do any wiring upgraade for this pump?
Old May 5, 2011 | 10:10 PM
five7kid's Avatar
It came with everything pictured.
I was starting with a carb'd car with no pump in the tank. I got an EFI pickup from a TGO member and ran all new wiring straight from the fuse/relay box to the pump.
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
