hawks lsx mounts
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
hawks lsx mounts
hey guys..im stuck right about to drop my motor in but im not sure the orientation of the mounts i bought from hawks.didnt come with any diagram of what bolt holes to use.im using the swap brackets and ls1 motor mount clamshells. need pics asap.thanks
Re: hawks lsx mounts
https://www.thirdgen.org/forums/post...34-post34.html
Pass side will only line up 3/4. Drill the last one yourself
While you're in there, Id suggest fabbing a simple nut plate because those nuts are a major PITA to get to
Engine: 2005 LQ4
Axle/Gears: 3:54
surprisingly the bolts arent bad to get to on a hoist and 2 universal joints and a few extension and a good light lol.i got lucky and guessed the correct configuration and drilled the hole.thanks alot though pocket..i wasnt sure if i had to move the brake lines either.now i know
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
I hope this isn't too off topic. but i've heard one of the mounts is farther back then the other on the bock of the LSx engines. is this true? which side is it and does the mounts make up for it?
They're even with each other (more or less), but both moved back on the K-member
LT1 mounts have an even/odd combo. Pass side is the oddball and wont work, use the 3rd gen SBC clamshells to remedy the issue
Car: '86 Z28
Transmission: WC T5
Maybe GM was planning on doing it different...
Found this pic when sifting through the assembly manual for my '86 this evening. I thought I'd post it for pure entertainment purposes only. I ordered and bought my car brand new and LB9 setup definitely did not come assembled this way:
I can see how it might be more difficult to service with studs set in a plate from the bottom instead of bolts from the top as it was assembled.
Mike
Mike
Last edited by mwfrels; Jun 2, 2011 at 09:04 PM. Reason: Clarified build configuration.
I built a nut plate because a stud plate would be difficult to get by the springs. Either would be easier to use over plain nuts/bolts which were all thats installed in any 3rd gen Ive taken apart. Never ran across the stud plates in that diagram and the PN is for a spacer
I've found the motor mounts aren't so hard if you take a 1 inch hole saw to the top center of the K Member. Then a wrench fits right in to capture the nut on the top 2 bolts. The bottom ones can be reached with a swivel socket.
Car: 83 Trans Am
Engine: Soon to be 6.0l LQ9
Transmission: Soon to be 4L60E
Ok...this is what I wanted clarification on when I asked a while ago, but I think I was unclear in my question. After seeing K-members in the junk yard I noticed some have the mounts forward on the K, and others are set back on the K.
So if I'm understanding this correctly, all K-members ARE the same, just use the holes that are further back? (oh, and this applies to spohn motor mounts too right?)
Engine: 2005 LQ4
Axle/Gears: 3:54
the spohn and hawks mounts are the same iirc. and they do bolt up on the back bolt pattern closest to the firewall.i found a good pic on a thread to verify this when i originally posted this thread.wish i saved it.as far as all k members being the same..id like to hope so.
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Guest
Posts: n/a
The V6 mounts have to come out, the V8 mounts can be used with mount plates if you don't want low-mount a/c
Guest
Posts: n/a
Bohemian
Aug 15, 2017 05:11 PM
BumpaD82
Feb 26, 2016 02:57 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
