LT1 engine problem
Old May 25, 2011 | 11:18 PM
karl's-92'-z28's Avatar
Car: Too many cars
LT1 engine problem
Ok engine was running sputered & died out i say after 15-20 mins.Next day started engine & it died out after 5 mins, havent turned it on since. Today enginge just cranks over & doesnt start or try to start. Fuel pump goes on, can hear it humming. What could the problem be? Optispark crapped out? its a bone stock engine in a '97.
Old May 26, 2011 | 10:48 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Re: LT1 engine problem
opti.. replace with AC Delco or Delphi.. or you will be replacing it again in 100 miles..
Old May 26, 2011 | 11:39 AM
Car: Too many cars
Thanx killjoy i figured it was the opticrap....hahaha
Old May 26, 2011 | 12:37 PM
Firebat's Avatar
Check the fuel pressure, just because the fuel pump is heard does not mean it is providing significant amount of pressure or mean the line is being somewhat clogged by a dirty fuel filter.
Old May 26, 2011 | 06:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Even a bad pump can make "normal" sounds.
Until you've verified fuel pressure and existence/lack of spark, you shouldn't be replacing anything.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
