4l80E Crossmember
4l80E Crossmember
Does anybody make a 4l80E conversion crossmember that has the torque arm mounted to it? The only conversion crossmember for the 80 that I have found is from BMR and it doesnt have the torque arm mounting to it. I would have to go with their extreme trak attack pack if I went that route. I would like to go with one company for all of my suspension for the car (92 Camaro). Oh I almost forgot I planning on installing a 6.0L as well.
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: 4l80E Crossmember
You would think they would at least offer a bolt on torque arm mount option since there isn't one on the 4L80E case.
But of course they do that so you have to buy their torque arm setup as well....
Transmission: 4L80E/4L80E
Call them up. Maybe they'll fab one up for you. Or, it's possible there isn't room for the relocation bracket they put on their other crossmembers.
Any particular reason everything has to come from the same place? Hard to imagine compatibility would be an issue. The Jegster TA allows you to use any tranny you want.
I like dealing with one company when I do things like suspension. Ive just had better luck with things like that. Because I probably will use all of there suspension and chassis parts as well.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kammi10
Nov 9, 2015 08:28 PM
tmork454
Sep 29, 2015 06:33 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
