Car craft LS1 camaro article
Old Jun 16, 2011 | 11:35 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
In the latest issue of car craft they did a spread on bang for the buck swaps. One of which was an '86 camaro which was built with the following parts:
Motor:
-5.3 block bored to 5.7 with LS1 pistons
-5.3 heads with ls1 valves(no casting number given)
-LS6 cam + valve springs
-LS6 intake manifold w/ 90mm throttle body
-stock cast exhaust manifolds
-4L60E w/ stock converter
They aren't clear about how they came up with the power output but they state, 444HP 434ft.lbs. I'm pulling out my card on this one. I'm trying to get the article scanned but my printer is not cooperating so I'll see what I can do.
Old Jun 16, 2011 | 11:46 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: Car craft LS1 camaro article
i saw that article, i hate how they half assed the AC job and just left it hanging in there and didnt even cap the condenser, they computer is sitting on top of the strut tower it looks like too, and they claim it has 93 camaro seats when it has the same seats as my 90.... Its a complete hack job imo so i wouldnt be surprised if the numbers are BS
Old Jun 16, 2011 | 11:58 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Need to pick up this article 444rwhp?
Old Jun 17, 2011 | 03:25 AM
Guest
Guest
Posts: n/a
444 HP at the crankshaft is plausible, if they're using STD correction rather than SAE.
Texas Speed has tested a stock LS1 to make 400 HP, at sTD correction, and the LS6 cam typically shows a 40 HP gain.
Moving on, those seats are definitely third gen, not fourth. Probably a typo, probably '92 seats.
The computer mounting: I would've rotated it 90 degrees, but otherwise it seems good to me.
The problem is that the "tech notes" at the end specifies a custom 2.5" exhaust system. But it doesn't specify "dual". A single 2.5 with no cat and no muff, but with mandrel bends, becomes a restriction above 260 HP ( at the crankshaft )
Lastly, note that the car owner's dad co-owns TPiS, so you can bet that the HP number came from the TPiS engine dyno.
Old Jun 17, 2011 | 07:41 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I believe it if they spun it fast enough. And yes tpis only has an engine dyno, wish they had a chassis dyno for us guys in south central MN
specialized
Jun 18, 2022 09:26 AM
1984HO
Mar 19, 2021 11:59 AM
NBrehm
Aug 25, 2015 11:49 PM
reiderz iroc
Aug 13, 2015 04:57 PM
makaveli09
Aug 12, 2015 09:07 PM
