LT1 1/4 Mile Times
Old Jun 18, 2011 | 12:49 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
LT1 1/4 Mile Times
Im trying to figure out if its worth the headache to swap from my weak 5.0 TBI to a LT1. What kind of times you guys running with LT1's?
Mods or no mods?
also on a side note, when swapping to a LT1 / 4l60e what needs to be done with the driveshaft?
Old Jun 18, 2011 | 01:35 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
Re: LT1 1/4 Mile Times
http://www.ls1tech.com/forums/lt1-lt...o-archive.html this is a large list of power ratings and track times
nothing needs to be done to the driveshaft except maybe put new u-joints in
Old Jun 18, 2011 | 01:44 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
If you can get it cheap enough yes. But as cheap as LT1's are, 5.3L Gen3 swaps can be had at nearly the same prices in some cases.
I have an LT1 in my car, and I'm happy with its performance.
It runs nearly bottom 13's on crappy, hard, old street tires.
Old Jun 18, 2011 | 09:02 PM
insomniac's Avatar
Engine: 5.7 L98
i assume swapping in a 5.3 3rd gen motor is much harder and more expensive though?
Old Jun 18, 2011 | 09:17 PM
Not really. The Gen 3 harnesses are pretty much stand alone. It basically needs a flash to remove VATS and other equipment you don't install with the engine.
Mounts can be had from hawks for about $90 I think.
*Found them, $85 on hawks website. http://www.hawksthirdgenparts.com/82...ountspair.aspx
After that its pretty much a direct drop in, the rest is just the harness and PCM wiring into the thirdgen. The electronic work is about the same between LT1 and Gen3 motors.
Get a Gen3/4L60E pull out from a junkyard with the harness and PCM and you'd have 90% of the parts needed for the swap right there. With some time and reading you could convert the harness on your own. Same as with the LT1 harness.
The big issue is usually accessories and the oil pan. Oil Pans are expensive, and the oilpans aren't just a pan. They are a structural part of the gen 3 engine.
Old Jun 18, 2011 | 09:23 PM
insomniac's Avatar
Engine: 5.7 L98
what about switching to obd2. is the obd2 connector part of the harness?
Old Jun 18, 2011 | 09:36 PM
https://www.thirdgen.org/forums/ltx-lsx/
If you can't find it there, then it doesn't exist. Don't wanna make another LTx/LSx swap thread. There are TONS of those, no need to duplicate the info.
Old Jun 18, 2011 | 11:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
My buddy's 95 Z28 went 12.96 at 106 on street tires in an automatic with stock stall, 3.73 gears, with most bolt ons and tune. In a thirdgen, low 13's-high 12's should be easily doable in good air with an exhaust/geared/tuned LT1 and with converter/slicks, it should be well into the 12's
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Thirim
Aug 9, 2015 06:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
