LT1 Charging issues.
Old Jun 24, 2011 | 07:10 PM
carkook's Avatar
So the LT1 is from a 95, It has one larger wire from the post on the alternator to the battery, and one wire on the plug on the back. I replaced the alternator after the last one started over charging. I had the wire for the plug going strait to a 12v junction.
Now after replacing the alt. the gauge on my IP doesnt change when the car is off and on, leading me to think the alt. isnt charging. I tried wiring a 470 ohm resistor inline with the wire that plugs into the back of the alt. still nothing.
Old Jun 24, 2011 | 09:29 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 Charging issues.
First alt likely burned up because it didnt have the resistor inline with the 12v source
Second sounds like a bad replacement. Have it tested
Old Jun 24, 2011 | 09:32 PM
carkook's Avatar
Sounds good thanks pocket. Is it possable that they gave me one that I have to have one pin get power and another the signal wire with the resistor?
Falcon50
Aug 22, 2020 03:26 PM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
