Spohn Tubular Kmember + LS1= Postive Camber...Whats the solution
Old Jul 6, 2011 | 03:22 AM
nhra-trans-am's Avatar
Got the LS1/4l60e into my 91 firebird and I am experiencing some positive camber. I am using a spohn tubular kmember with the stock v6 spring/shock setup. I heard there were plate for adjusting the camber, but just wanted to see if anyone else experienced this and what the options were. Thanks.
Old Jul 6, 2011 | 10:50 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Spohn Tubular Kmember + LS1= Postive Camber...Whats the solution
since my factory rubber mounts were shot to begin with, i opted to grab a set of the founder performance pieces. very nice quality, more adjustable, and only slightly more expensive than getting a good quality stock replacement version.
Old Jul 8, 2011 | 02:57 AM
Cool. That sounds like just what I need. Is that the route most people go or are there other options.
Old Jul 8, 2011 | 04:04 AM
bigals87z28's Avatar
Car: Check The Sig
I would check your lower control arms and make sure that they are installed correctly. Are you out of adjustment up top in the strut mounts?
Falcon50
Aug 22, 2020 03:26 PM
loud91rs
Oct 5, 2015 10:05 PM
